(Draft) How-To: Get more info. from your MINI's cpu (Digital RPM, Speed, Volts etc) - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Closed Thread
  #31 (permalink)
Old Sep 14th, 2003, 11:40 PM
TomM's Avatar
Local Time: 07:30 PM
United States View TomM's Solid Black & Body Color 1st Gen MINI Cooper S Profile
I must have done it wrong the first time. Everything works fine on my Sat-Nav 03 MCS. Cool find, Paul and thanks for that list of stuff minimarkcs.
  #32 (permalink)
Old Sep 15th, 2003, 02:57 AM
gazah's Avatar
M2 Procrastinator
Local Time: 10:30 AM
Australia View gazah's British Racing Green & White 1st Gen MINI Cooper S Profile
what did paul say about not being responsible for any damage to your car...
if it wasn't called a test, 2.0 sounds just a little dangerous from the report above!
  #33 (permalink)
Old Sep 21st, 2003, 07:39 AM
minimarkcs's Avatar
Send a message via AIM to minimarkcs
Local Time: 01:30 AM
Germany View minimarkcs's Dark Silver & Black 1st Gen MINI Cooper S Profile
No, it's not dangerous.
Menu 2.0 allows you to check that all instruments and dash lights are working properly. The Speedo and Rev. counter needles swing round to the end and back again to make sure that they can move freely and possibly to calibrate ? Not sure on that either but it certainly looks good when the displays all go bonkers.
You can't do any damage with these menu's, except perhaps messing up the fuel consumption display in menu 20.0. It's a great time waster when you're stuck in a traffic jam, though
BTW. Thanks @all for the applause.
Passengers ride at own risk !
  #34 (permalink)
Old Sep 22nd, 2003, 04:03 AM
Local Time: 04:30 PM
United States View scott_roberts's Indi Blue & White 1st Gen MINI Cooper Profile
Wow, gotta go try this. So after you turn the car off, does it re-display the mileage? Or does it continue to display whatever you've selected?
  #35 (permalink)
Old Sep 22nd, 2003, 04:51 AM
gazah's Avatar
M2 Procrastinator
all goes back to normal when you turn the car off... check out the first post again for full details!
  #36 (permalink)
Old Sep 22nd, 2003, 08:17 AM
Hat's Avatar
Hat
ITS RAINNIN' SIDEWAYS
Local Time: 12:30 AM
England Male View Hat's Classified Ads
4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms.
4.1 Consumption in liters/100kms.
5.0 Distance consumption in l/100kms.
5.1 Actual rest distance with available fuel in Kms.
has anyone managed to work out the difference between 4.0, 4.1 & 5.0 or how this works?:
20.0 Correction factor for Fuel consumption
Formula for correction:
Shown consumption x 1000 / user defined consumption
Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button.
  #37 (permalink)
Old Sep 22nd, 2003, 02:53 PM
Netherlands View mhoutman's British Racing Green & White 1st Gen MINI Cooper S Profile
here is the complete DIY manual (got it from a German site)
I especially like 2.0 Kombisystemtest as it appears that there are actually more red leds in the revs counter as you will see.
"Anleitung fürs auslesen bzw anzeigen des internen Bordcomputers...
Die Anzeigen erscheinen anstatt der Kilometeranzeige.
1. Rückstellknopf des Tageskilometerzählers drücken und gedrückt halten. Dabei den Schlüssel auf Position I drehen.
2. Sobald die Anzeige "test 1.-" erscheint, den Rückstellknopf so oft drücken, bis das Display "test 19.-" anzeigt (nicht zu lange warten, weil Ihr sonst im ersten Menü stecken bleibst und alles
wiederholen müsst).
3. Um alle Menüs nutzen zu können, müsst Ihr diese nun "entriegeln".
Dazu wartest Ihr kurz, bis die Anzeige "Log I-off" erscheint, und drückt dann wieder so oft den Rückstellknopf, bis das von euch gewünschte Menü erscheint. Wollt Ihr z. B. den Digitaltacho nutzen, drückt Ihr also so oft, bis die Anzeige "test 7.-" erscheint und wartet kurz, bis Ihr im Menü "eingelogt" werdet. Das erkennt Ihr daran, dass das Display "test 7.0" anzeigt. Nun könnst Ihr (auch
nachdem Ihr den Motor schon angelassen habt) wieder durch Drücken des Rückstellknopfes zwischen den Menüunterpunkten wechseln, z. B. für die Geschwindigkeitsanzeige den Punkt 7.3.
Test1.0 Fahrgestellnummer
1.1 K-Zahl Tacho
1.2 Teilenummer
1.3 Codier-,Diagnose-,Busindex
1.4 Herstelldatum KW/J
1.5 Hard- und Softwarestand
1.6 Einspritzstatus-Zylinderzahl-Motorfaktor
2.0 Kombisystemtest
3.0 ServiceIntervall Grundlage der Berechnung in Liter
3.1 Anzahl der Tage bis zur Zeitinspektion
4.0 Momentanverbrauch in l/100km Anzeige z.B.0154=15,4l
4.1 Verbrauch in l/h
5.0 Reichweitenverbrauch in l/100km
5.1 Reichweite momentan in km
6.0 Tankinhalt gemittelt z.B. 123321=12,3links 32,1 rechts
6.1 Tankinhalt gesamt
6.2 Anzeigewert an der Tankuhr und letzte Zahl wenn 1 dann
beide Geber ok,bei 2 Geberfehler bei 3 ti Signal unplausibel=keine Anzeige
7.0 Kühlmitteltemperatur momentan
7.1 Aussentemperatur momentan
7.2 Drehzahl Motor momentan
7.3 Momentangeschwindigkeit
8.0 Hexadezimale Darstellung der Werte von 7.0 bis 7.3
9.0 Bordnetzspannung in Volt
10.0 Ländercodierung
11.0 Einheitencodierung
12.0 Nicht belegt
13.0 Gongtest
14.0-14.4 Fehlerspeicher bei 000000 kein Fehler gespeichert
15.0 - 18.0 nicht belegt
19.0 Ent-/Verriegelung der Testfunktionen 3-20
Anzeige springt im Sek. Rhytmus von I_on auf I_off
Entriegeln: Bei Anzeige I-off Taste drücken
Verriegeln: Nach Verlassen der Testfunktionen automatisch
20.0 Korrekturfaktor Verbrauch
Formel für Korrekturfaktor:
Angezeigter Verbr. X 1000 / Ermittelter Verbrauch = Faktor
Durch Druck auf die Kombitaste beginnt der Einstellvorgang der Einerstellen
Zahlen beginnen von 0-9 zu wechseln wenn die richtige Zahl aufleuchtet Taste drücken
20.1 Einstellung der Zehnerstelle
20.2 Einstellung der 100 und 1000er Stelle
20.3 Speicherung und Anzeige des eingestellten Wertes
21.0 Software Reset (Wirkung wie Batterie abklemmen)
wiederholen müsst).
1.1 K-Zahl Tacho
1.2 Teilenummer
2.0 Kombisystemtest
12.0 Nicht belegt
13.0 Gongtest
very "Works".
  #38 (permalink)
Old Sep 22nd, 2003, 03:41 PM
Paul's Avatar
MINI2 No.1
Local Time: 11:30 PM
England Male
We already have that, better close this as it's already a full FAQ item now....
http://www.mini2.com/forum/faq.php?f..._obc_functions
  #39 (permalink)
Old Sep 22nd, 2003, 05:38 PM
minimarkcs's Avatar
Before you close up Paul, I just wanted to mention that the above list in German is what I translated from and I've now noticed a few mistakes.
Menu 4.0 should read :
Actual fuel consumption in l/100kms. (Meaning it reads as you go, don't leave it in this menu when you hit the throttle, you won't like what you see !)
Menu 4.1 should read :
Fuel consumption in liters/hour.
I also couldn't quite figure out how to use the Consumption factor properly but it seems that you can fine adjust it to get a more accurate reading.
  #40 (permalink)
Old Sep 22nd, 2003, 05:42 PM
Paul's Avatar
MINI2 No.1
England Male
Thanks.
Closed Thread
Digital Info Display Issue Stella1 Canada 1 Jan 13th, 2007 10:12 PM
Digital Speed Display SimonD First Generation MINI Cooper S 3 Mar 22nd, 2005 10:19 PM
New DIY:How to show RPM, Fuel Levels, Speed and more on your Odometer Digital Display Paul General Discussion 8 Sep 20th, 2003 02:22 PM
Speed and RPM in each gear Addicted_to_S First Generation MINI Cooper S 11 Jun 23rd, 2002 07:30 PM
