| beat you aiden... must've printed a coupla minutes before you! now i realise you ran out of ink while i was typing! ... sucker! ![]() oct '02 MCS & it all works as above! make sure you hit the reset button while it says "log i-off", as hitting it while "log i-on" is displayed will exit the test! 7.0 - Temp must be in fahrenheit - 37 @ Rest / 61 After 100m 7.1 - Dunno / sat around 145-9 @ rest & didn't budge much after startingor driving 7.2 - RPM as above / Fairly responsive actually 7.3 - Speed / Jumps about as described earlier / OK with smooth acceleration / Must update in set time increments rather than speed increments as it'll easily do 1km/h increments when driving slowly! 9.0 - Volts would seem reasonable given the figure, but it says ~140 is that deciVolts or something?now we just have to wait for mini to allow a digital aftermarket console that displays ALL this stuff at once! ![]() .g Last edited by gazah; Sep 14th, 2003 at 11:04 AM. |
| TomM - i think i know where you went wrong, try this exactly... * hold reset / turn key to position 1... release reset * scroll through to 19 [i mad 1 / 2 / 10 / 19 only]... wait a second * scroll through to 7 [or 9 for volts as above]... wait a second * [i think this is where you went wrong, & only scrolled through to 1] * scroll through from 7.0 to 7.3 with displays as above! i may be wrong, & it may be an '03 or satnav issue, but give it a go! cheers .g |
| Digital Info Display Issue | Stella1 | Canada | 1 | Jan 13th, 2007 10:12 PM |
| Digital Speed Display | SimonD | First Generation MINI Cooper S | 3 | Mar 22nd, 2005 10:19 PM |
| New DIY:How to show RPM, Fuel Levels, Speed and more on your Odometer Digital Display | Paul | General Discussion | 8 | Sep 20th, 2003 02:22 PM |
| Speed and RPM in each gear | Addicted_to_S | First Generation MINI Cooper S | 11 | Jun 23rd, 2002 07:30 PM |
