Ipod newbie - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 28th, 2004, 06:13 PM
Jimbob's Avatar
Local Time: 05:02 AM
United Kingdom View Jimbob's Pure Silver & Black 1st Gen MINI One Profile
Ipod newbie
Not sure if this is in the right forum but here goes. I'm thinking of getting an Ipod. The question is how do I get the music from my CDs to the Ipod? Yes I know it's a dumb question! I've got a laptop with a CD drive so I guess this is "ripping" the tracks to the hard drive? Do I need some s/w to do this? The easy bit seems to be getting the files from the PC to Ipod which I'm assuming is just drag and drop. Any Ipod websites for beginners you could recommend?
TIA.
Old Jan 28th, 2004, 06:19 PM
snid's Avatar
brown is back
Local Time: 12:02 AM
United States Male View snid's Velvet Red & White 1st Gen MINI Cooper Profile
iTunes - http://www.apple.com/itunes/overview.html
Learn it, Love it
For more advanced iPod stuff (once you actually get one and get bored using iTunes):
http://www.ipodlounge.com/
http://www.ipoding.com/
They usually overlap in content a fair amount, though
jtross | snid | jason - bloggage (including videos)
Old Jan 28th, 2004, 06:24 PM
MarkW19's Avatar
Grinning
United Kingdom Male View MarkW19's Astro Black & Body Color 1st Gen MINI Cooper S Profile View MarkW19's Classified Ads
The iPod comes with (or you can download it F.O.C.) iTunes, which is like a jukebox application. You insert a CD, it assigns tracknames, and downloads the tracks to your computer.
Then, the next time you plug in your iPod, it automatically opens iTunes, and "updates" your iPod to match iTunes exactly, as far as songs etc. go. So there's not even a need for drag and drop, it's all automatic! Unless you want to do it manually of course.
iTunes/iPod also encode tracks as AACs (Advanced Audio Codec) which is better quality than, but still the same size as, mp3s, so it sounds great!
Old Jan 28th, 2004, 06:38 PM
dinlo's Avatar
MINI2 Master / Moderator
Send a message via ICQ to dinlo
Local Time: 09:02 PM
United States View dinlo's Dark Silver & White 1st Gen MINI Cooper S Profile
If you are using a PC, I will recommend MusicMatch® It should come with the Ipod.
1962 mini, 2004 MCS, 2003 MCS, 1965 mini
Click here to NorCalMINIs.com
Old Jan 28th, 2004, 07:00 PM
bobbagum's Avatar
Send a message via ICQ to bobbagum Send a message via AIM to bobbagum Send a message via Yahoo to bobbagum
Local Time: 04:02 AM
Thailand
As others have pointed out, you will be using the freely downloadable iTunes, which works with both Mac and PC (also comes with the ipod) www.apple.com/itunes , which will be used to "rip" CDs to your computer, which will be copied to the ipod whenever you connect it to the computer, or you can do it manually, just copying each songs. You can download and play with iTunes now if you'd like, and see how you like it, it probably is the best music program out there, if you ended up not getting the iPod, you can use iTunes to play music on your computer still.
One thing to keep in mind though, is that if your computer don't have a Firewire or iLink port, you'll need another USB cable from apple, and that only works if your computer have USB2.0,
Last edited by bobbagum; Jan 28th, 2004 at 08:25 PM. Reason: Correccted the broken link
Old Jan 28th, 2004, 07:37 PM
Jimbob's Avatar
Thanks for your advice everyone.
My laptop has USB ports but not sure if they're 2.0.
It also has something called iLINK (IEEE1394) which I've never used - will that work?
Old Jan 28th, 2004, 08:08 PM
That is firewire (IEEE1384) that'll work beautifully
Old Jan 28th, 2004, 08:55 PM
Aqualung's Avatar
Sitting on a park bench..
United States View Aqualung's Indi Blue & Black 1st Gen MINI Cooper S Profile
iPodLounge
Here is another great user community, http://ipodlounge.com/forums/forumdi...php?forumid=45
This link is for the iTunes, but they have generic iPod forums for Windows, e.g. General info, etc. If you don't like MusicMatch or iTunes, there's also Ephpod which I used for awhile, until switching to iTunes.
Old Jan 28th, 2004, 08:57 PM
Aqualung's Avatar
re: laptop IEEE
It will work, but typically the laptop versions of IEEE 1394 (aka FireWire) has its power leads disabled, which helps to lower its power consumption. If you plug your iPod into a desktop FireWire port, it will charge in addition to allowing you to synch...just so you know.
With the laptop, to charge you'll have to use the wall AC adapter.
Old Jan 29th, 2004, 07:41 AM
Jimbob's Avatar
Thanks again all.
Another question - if I was to buy an Ipod on a trip to the US (given the favourable exchange rate) would I have problems using it in the UK? I'm assuming the Ipod will tolerate mains voltage differences and therefore it's just the AC adaptor I would need to change?
Old Jan 29th, 2004, 09:27 AM
scooperman_uk's Avatar
almost 59k
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile
the mains adaptor you get with the IPOD allows different PLUG heads to be slid on and off the main base. i assume this deals with the power management. Apple sell a world travel kit with all the plugs, which is pricey tho. if u buy in the states u get the 2 pin plug in the box to slot on, if u buy in the uk u get the 3 pin plug to slot in. as simple as that. i dont think theres any issues caused by voltage diffs.
Old Jan 29th, 2004, 12:16 PM
snid's Avatar
brown is back
The only difference I'm aware of between a US iPod and a UK (or was it EU) one (beside plugs / voltages - which should be AC adapter only) is that the US ones are louder (our's go to 11). Some regulation over there that limits maximum volume.
At least, I remember reading that on one of the iPod sites. Perhaps it was an urban legend.
Old Jan 29th, 2004, 12:18 PM
Aqualung's Avatar
no problem...
Thanks again all.
As Scooperman says, no probs with using your iPod in the UK, I go to Europe all the time. One strongly suggested accessory is the Belkin battery pack here http://catalog.belkin.com/IWCatProdu...duct_Id=148969
the 3G iPods are being dissed for their lower battery life, esp. the 30GB and higher models that I have. I'm only able to get 4-5 hrs out of the charge, barely enough for the transatlantic flight (counting waiting time).
I also use the car adapter here http://catalog.belkin.com/IWCatProdu...duct_Id=149006 because it has a powered line out, which goes into the Aux jack.
Up until Jan 31st, Belkin is offering 50% off everything on the site if you use this promo code: 35491
Old Jan 29th, 2004, 12:19 PM
Aqualung's Avatar
not urban legend....but...
my understanding is if you reformat, with the Updater (now at 2.1) from the US specs, it should eliminate this.
Check out ipodlounge and do a search for this topic...
Wierd ipod idea/request...ipod + speaker...no stereo bimini First Generation Interior & Ice 1 Apr 6th, 2006 09:28 PM
Official MINI iPod adaptor not compatible with iPod Nano! Mini Lou First Generation Interior & Ice 12 Mar 13th, 2006 02:16 PM
Newbie Ipod question paco71 First Generation Interior & Ice 0 Sep 26th, 2005 02:27 PM
iPod Photo work with iPod Interface? Any success stories? Adgeman First Generation Interior & Ice 2 Feb 5th, 2005 05:04 AM
Ipod, add-a-circuit, aux & 12v on parcel shelf, : (formerly:'30gb ipod on Dell') averyocooper First Generation Interior & Ice 29 Mar 7th, 2004 05:27 PM
