feedback with ipod - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 18th, 2004, 03:07 AM
luxmedic
Local Time: 01:17 AM
United-States feedback with ipod
i have an ipod plugged directly into the aux. slot in the back of the harmon kardon upgrade stereo. the ipod is also plugged into a dc to ac converter via the cig. lighter, so as to keep it charged up. problem is: when i play the ipod through the stereo there is loud hum when it is plugged into the dc/ac converter. when i unplug it from the ac/dc converter there is no hum but then the battery runs down. any ideas how i could fix this? thanks so much.
Old Mar 18th, 2004, 04:28 AM
antsmini's Avatar
Resident MINI Hairloss Dr
Send a message via AIM to antsmini
Local Time: 02:17 AM
United States View antsmini's Chili Red & White 1st Gen MINI Cooper Profile
I have mine plugged into a Belkin cig lighter charger. The AUX jack plugs into the Belkin then the Belkin plugs into the iPod. I get the same feedback. Any ideas would be great. I think someone mention a ground loop insulator?
Old Mar 18th, 2004, 05:28 AM
Local Time: 12:17 AM
United States View nickp's Chili Red & White 1st Gen MINI Cooper Profile View nickp's Classified Ads
Yes, a ground loop isolator should take care of this.
I purchased mine from Radio Shack for around $15
http://www.radioshack.com/product.as...t%5Fid=270-054
If you're ambitious, someone on MINI2 posted diagrams for building your own smaller and cheaper Ground Loop Isolator, but I'd say just chip in the $15. Depending on the location of your AUX input, you can hide the GLI under the dash (I put mine behind the little pull-out panel behind the toggle switches)
-Nick
Old Mar 18th, 2004, 05:38 AM
antsmini's Avatar
Can you explain how that hooks up. Looking at the pic I cant tell where I hook that to...
Old Mar 18th, 2004, 01:59 PM
Don't worry, its just plug in and go. In the picture, there's a little adapter that converts the Stereo RCA (Red and White) plugs to a mini-jack. It comes with one of these adapters, and you'll need a second adapter (Here at Radio Shack, around $5). That way you essentially have two mini-jack plugs with a Ground Loop Isolator between them.
Ipod (Or Belkin Car Adapter) -> Mini-Jack (Ground Loop Isolator) Mini-Jack ->AUX input.
Hope that helps!
-Nick
Old Mar 18th, 2004, 04:10 PM
United States View elbee's Pure Silver & Body Color 1st Gen MINI Cooper S Profile
Not to be controversial but I have to ask. What's the big deal with the ipod? It has 4 hours of battery life, non-replaceable batteries. It is only Mac compliant, not further elaboration needed. Why not get a windows compliant unit? I can't figure out why everyone is so gung-ho about the ipod. Ooohhh, the ipod; I don't get it, can someone please explain.
Old Mar 18th, 2004, 04:32 PM
mrdatalife's Avatar
i get more than 4hrs, but won't split hairs on that one. and yes, you CAN replace the battery.
the iPod IS windows compliant. i use with WinXP just about everyday!
and yes, buy one. it might be the only apple product i buy, but i'm glad i did. the iPod is great.
Old Mar 18th, 2004, 07:36 PM
averyocooper's Avatar
Local Time: 11:17 PM
I use the belkin as well and initially got the hum. you need to lower your aux input volume on the head unit. if it is set too high you will get a hum or static. using the belkin and the dock connector as the audio output you can achieve great volume w/o maxing out the aux input level on the head unit.
if you try to use the headphone jack as your audio out you will have to use the volume on the ipod instead of the head unit and then you will have all sorts of volume annoyances.
-averyocooper
ps. i use my ipod with windows xp running musicmatch (not itunes), the battery last MUCH longer than 4 hours but i don't have to worry about that since i charge while i drive with the belkin audio out/charger dock connection.
Old Mar 18th, 2004, 10:08 PM
I'll do a little more research. I have the mindset that everything is windows so why bounce to mac for this.
Old Mar 18th, 2004, 11:56 PM
mrdatalife's Avatar
yup...i had that same conern.
i can say after the fact that it's well worth it.
Old Mar 19th, 2004, 04:56 AM
luxmedic
because it is lovely
rechargable
pc friendly
etc.
what more?
blessings
Old Mar 19th, 2004, 09:24 AM
bobbagum's Avatar
Send a message via ICQ to bobbagum Send a message via AIM to bobbagum Send a message via Yahoo to bobbagum
Local Time: 06:17 AM
Thailand
What's the big deal with the MINI? it's small and overpriced.... blah blah blah
Wierd ipod idea/request...ipod + speaker...no stereo bimini First Generation Interior & Ice 1 Apr 6th, 2006 09:28 PM
Official MINI iPod adaptor not compatible with iPod Nano! Mini Lou First Generation Interior & Ice 12 Mar 13th, 2006 02:16 PM
iPod Photo work with iPod Interface? Any success stories? Adgeman First Generation Interior & Ice 2 Feb 5th, 2005 05:04 AM
Ipod, add-a-circuit, aux & 12v on parcel shelf, : (formerly:'30gb ipod on Dell') averyocooper First Generation Interior & Ice 29 Mar 7th, 2004 05:27 PM
