Removal of Rear Seats - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 28th, 2002, 02:17 PM
Colorado "S"'s Avatar
Send a message via Yahoo to Colorado "S"
Local Time: 05:05 AM
Is anyone else contemplating removing the rear seats all together?
I really like the idea of a two seat hatch, and don't like how when the rear seats are just laid down there isn't a flat floor. So, I'm curious has anyone looked into having a false floor built (similar to what you'd use to hide a sub).
I gather the seat backs should be fairly easy to get out, but what about the rear seat bench?
Old Mar 28th, 2002, 02:24 PM
smiffy's Avatar
Send a message via MSN to smiffy
Local Time: 12:05 PM
Wales View smiffy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Check the MINI Mania site, they have a race prep Cooper Not sure if its been striped though
S for Smiffy
"Kids in the front seat cause accidents, accidents in the backseat cause kids!"
Old Mar 28th, 2002, 03:17 PM
Racer's Avatar
Blast from the past !
Send a message via ICQ to Racer
View Racer's Kawasaki Green & White 1st Gen MINI Cooper Profile
Re: Removal of Rear Seats
Bench just clips out - Rear seats in a club sport are pretty useless since roll cage means youu can't sit in them but also prevents them from folding flat
Old Mar 28th, 2002, 03:31 PM
Great! Thanks. Is there anything under the bench once its removed, or is it just carpeted? In my Jetta, with the seat cushions out, the access hatch to get to the fuel pump in the gas tank is visable.
Old Mar 29th, 2002, 09:19 AM
chiph's Avatar
Spectator
Local Time: 08:05 AM
United States View chiph's Electric Blue & White 1st Gen MINI Cooper S Profile
I've given this some thought. But since I haven't seen a MINI in person yet, I'm not sure how I would proceed. I imagine there's a dip where the seat bottoms go, and if I were to carpet that, it might be nice to hold things (keep them from sliding around too much).
Chip H.
ex-MINI Cooper S owner and all around good-guy
Old Apr 29th, 2002, 01:19 PM
Local Time: 07:05 AM
removing rear seats
I too would like to remove the rear seats. I don't have a MINI yet, but I was able to remove the seat bench easily on a test-drive car. Removing the seat backs will probably be more involved (tools needed). There is no carpeting under the seats, just metal and a couple of round plastic bits (I assume they are access panels for something.
I would like to take the seats out and put in a piece of carpet and maybe something to make one big flat surface.
Can anyone comment on what's involved to remove the seat backs? If anyone has photos of a MINI with no back seats I'd like to see them.
Old Apr 29th, 2002, 02:29 PM
Minty's Avatar
Man in the know!
Send a message via MSN to Minty
You should get in touch with Smoothass
He has one bucket seat installed in the back of this car:
Stephen
MINI-3 @ Cotswold MINI | BMW-four @ Cotswold BMW | E-Mail Me | Minty - Part of the IT Crowd!
Old May 2nd, 2002, 01:21 PM
Local Time: 01:05 PM
England
Rear seat removal.
1 Remove seat bench.
2 fold seats flat, headrests down.
3 remove the 10mm bolt from anchor point between the seats.
4 flip the catch plate on the top of the anchor point upwards freeing the seat pivots.
5 starting with the left seat (theres a reason for this believe me!!) gently pull the seat pivot upwards and free of the anchorage point but don't tip the seat upwards more than necessary.
6 Whilst applying gentle sidewards pressure to the seat, inwards toward the centre of the car (pull it from the bottom only level with the outer pivot point)tilt the seat fowards and backwards until it frees itself from its outer fixing point. The pivots have two pegs which pop out from the fixing point in the right tilt posistion (usually around 45 degree tilt forwards)
Take care not to move the seat too much any other way but forwards and backwards tilt,or the outer fixing point will break. Try to move the seat only as much it does when fixed in place, only allowing just enough tilt to clear the other seat when it pulls free.
7 repeat for the right side.
8 to rebuild just reverse the sequence. Right seat first, Left second. Notice that the left seat automatically shuts the locking latch when you push it home, that's why you remove it first, replace it last.
9 The 10mm bolt should be 10nm torque but hand tight is ok.
10 on replacing the seat pan, pop the two clips at the front first then with your fists together give a fast and sharp blow downwards on the seat just behind the seat belt anchor points. It should click home. you sometimes dont hear the click but just make sure the seat doesn't pull upwards at the rear.
Hope this helps.
ps, seat removal breaches warranty.
Old May 2nd, 2002, 06:03 PM
chiph's Avatar
Spectator
Re: Rear seat removal.
Originally posted by MiNiGuY
<snip> seat removal <snip>
Thanks for the info, MiNiGuY.
This info is probably also useful to people installing amplifiers in the boot (remove seats to make it easier to run 4ga power cable from engine compartment).
Chip H.
Old May 2nd, 2002, 08:26 PM
Garfield's Avatar
So, am I to understand that the bench portion of the rear seat simply pulls out? No tools needed? Any type of latch?
Thanks,
Brian
- 2005 G Stock '05 MINI or it's back to a Miata in C Stock
- 2004 G Stock 2nd place Pro Solo, 9th Place Solo II
- 2003 STX 5th place Pro Solo, 6th Place Solo II
- 2002 H Stock Pro Solo National Champion
Old May 4th, 2002, 01:22 PM
England
Bench removal
Three clips on the bench.
One at each corner at the front.
One at the rear in the middle.
To remove it pull it up sharply at each front corner to release those clips.
Then grab the whole seat and just yank it out of the rear clip.
To replace it, see my earlier post.
Old Nov 6th, 2002, 12:52 AM
Local Time: 04:05 AM
2003 bench is different
i removed the rear seat backs as you described, but with the bench still in place. i couldn't get it out. the front lower corners are clipped in as you describe and i pulled more forward than up. but my 2003 bench is also attached at each back corner. i tugged both front-to-back and vertically, but couldn't get it out. i'll look for fasteners later....
i've weighed the seat backs and mine are lighter than previously reported: 27.5 lbs for the pair. the jack is 5 lbs. i'll update the weights when i get the bench, attach hardware and the rear belts out.
Old Nov 6th, 2002, 02:23 AM
Dom's Avatar
Dom
Test thread infiltrator
Send a message via MSN to Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile
Re: 2003 bench is different
It's hooked in the middle at the back, try pushing it down slightly there.
Guess who's done this a few times now
Dom
Old Sep 11th, 2010, 09:14 AM
It should be 2 pieces regardless of whether or not it folds down
unless they changed it my b12 sentra's back seat was 2 peices and that didn't fold down there should be 2 or 3 bolts between the top and bottom parts of the seat to take the bottom off the top honestly i'm not sure....
Last edited by minicore; Nov 4th, 2010 at 04:50 PM. Reason: Remove unrelated spam link.
  #15 (permalink)
Old Nov 4th, 2010, 04:03 PM
I realize this is trying to wake a long dead thread, but i broke the outer fixing point, im pretty sure because i managed to remove my right seat in 3 seconds and i had been working on the left seat for 15 minutes. What do i do to solve this problem? im trying to wire my stereo and i need my seats out for wiring, dynamat, etc. and ideas?
Rear seat removal - GP GTT 280 First Generation Interior & Ice 3 Jul 14th, 2006 02:30 PM
05 Rear seat removal? russ.mackay First Generation Interior & Ice 0 May 5th, 2005 07:51 AM
Rear light removal MICKEY First Generation MINI Exterior 18 May 12th, 2004 01:19 AM
Rear bumper removal uua First Generation MINI Exterior 3 Dec 30th, 2002 10:28 PM
Rear Bumper Removal Johnboy Maintenance & MINI Care 1 Oct 28th, 2002 02:36 PM
