| Yes, both sacrificied. In fact the original clock is stored safely at home. I bought another clock enclosure for the project. The ipod was completely disassembled and major surgery took place on the lcd element to get rid of original white backlight and to add orange smd leds and power/dimming capability from clock backlight power. Sacrificing the ipod was no issue for me as I never used it as a portable device, just for the car to replace cds... For security... I'll have to trust the Mini alarm! |
| I had to redo the backlight system. The original ipod has three smd LEDs on the left side of the lcd and a light difracting glass that uniformly distributes light in the back of the lcd. As I was not going to use the ipod backlight circuit (I wanted the backlight to turn on with the ligths of the car, so it had to be an independent circuit from the ipod), I exposed completely the back side of the lcd removing the conductive glass and added my own circuit board with 9 orange smd LEDs that are hooked up to the original mini clock backlight signal. If you just want to change the backlight on a regular ipod (and are not affraid of opening up the ipod!), changing the leds is pretty straight forward. The LCD module has on the backside a small pcb holding the three white leds. With a cutter or small flat screwdriver you can pop it out easily to expose the leds Then you just need to find same type of LEDs in orange or whatever color you want to add. I never got to checking what voltage/current they were using BTW, this is for an original ipod with mechanic scroll wheel. From what I know it also works with the second generation ipods (10 and 20GB) with touch sensitive wheel. Don't know about 3rd gen. ipods, sorry! One issue I encountered and I still have to figure out is that once backlight is turned on on the ipod, the lcd image is inverted so that light coming from behind, shows as black text over white background, like when no backlight is on (the explanation has to do with polarization and how lcds work...). So in my design, I will have to add a circuit that gives out a long pulse (about 3 seconds) to the menu button when car lights are turned on (this would have the same function as pressing "menu" long enough to turn on the backlight), and hence invert the lcd so the image shows black text over orange background. When lights are turned off, same pulse will be sent to "menu" button to turn off backlight again. But, still have to figure out this circuit... Hope this helps! |
| Best iPod install ever! (read in voice of "comic book guy" from "the simpsons") this is truely a great install. would be cooler if you could figure a way to make it removeable (at least in part) to sync to a desktop computer. |
| Hi xavicol, Very impressive, not least unique! Good luck with your work and please keep us all updated ![]() I'm in the process of replacing my 2-year-old 5GB 1Gen iPod with a new one on the way from HK... until I sling it on eBay, this leaves me with a spare iPod. It would be very cool to use the new one with the Ice-Link connector/dock, and use the old one as a slaved display, but I'm pretty sure it can't be done. To do this properly it might be best to use an HU-sized PC, as there's very little you can do with >1 iPod in the same place at any one time. Unless you have any ideas? BOUGHT 2003 - SOLD 2009 - gone to Pistonheads! |
| cheapest ipod integration | rene_73 | First Generation Interior & Ice | 6 | Sep 24th, 2007 11:16 AM |
| Which iPod integration to choose? | Deadliner | First Generation Interior & Ice | 8 | Sep 19th, 2007 10:46 AM |
| New style iPod integration - DICE | TouringComet | First Generation Interior & Ice | 8 | Jul 3rd, 2006 08:07 AM |
| alpine ipod integration | scottyjj | First Generation Interior & Ice | 1 | Aug 1st, 2004 09:34 PM |
| Apine Ipod integration- more information | PB | First Generation Interior & Ice | 7 | Jul 25th, 2004 08:16 AM |
