Front Cup Holder used as Camera Mount - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 30th, 2004, 07:38 PM
Restyle's Avatar
Damned
Local Time: 12:05 AM
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
I posted on My Rear Cup Holder Camera Mount a couple of weeks ago
See >> http://www.mini2.com/forum/first-generation-interior-ice/56458-rear-cup-holder-used-camera-mount.html <<
Today I experimented with trying to do a similar thing with the Front Cup Holder
I still used, as my material of Choice, The standard 68mm OD Drainpipe section which is easily deformed / bent with a little heat from a Heatgun, (although a Hairdryer will yield similar results). The pipe section has to stepped in order to clear the central switch cluster & Gearchange. It was then a simple matter of slipping the Camera mount I had previously made for the Rear Device onto this new, (albeit identical), section.
To reduce lateral movement I made up a Velcro strap which simply threads through the end switch guard & wraps around the pipe.
This method of monting now gives easier control of the Camera Functions & allows an unobscured view of the Road ... Ideal for any forthcoming Adventures .
I`ll post a Vid in the next few days
Name:	Heated & Bent Pipe.jpg
ID:	36582   Click image for larger version
Name:	Camera Mount unit fits in Pipe Adaptor.jpg
ID:	36583   Click image for larger version
Name:	Velcro`d Strap provides Lateral Support.jpg
ID:	36584   Click image for larger version
Name:	Control Arm Allows for easy Panning.jpg
Old May 1st, 2004, 04:15 PM
Restyle's Avatar
Damned
Ha, I take it Everyone must be totally stunned by my Plastic PipeWork judging from the Response to this Post
Took it for a few test drives today & also found that the "Steady Bar" I had made for the Rear Cam mount [Coincidentally] also fitted between the new mount & the Front Belt Fixing
As well as trying it out on Fast Country Lanes, I also tried it on a Cobbled Street as can be seen here which really give it a ShakeDown
Name:	Seat Belt Strut attatched.jpg
Old May 1st, 2004, 04:24 PM
CLiVE
Guest
Posts: n/a
Again, neat invention. The video looks very smooth.
I found another option. IMO this is basically all you need for a camera mount.
http://www.clamperpod.com/
There is enough space to clamp it to the front of the dash, (above the speedo) as well.
Cheers,
-R
What cup fits in the cup holder? MiniSoul First Generation Interior & Ice 17 Jun 7th, 2007 02:34 AM
Front Ash Tray in Cup Holder miniman23 Second Generation Interior & Ice 25 Jan 12th, 2007 06:59 PM
Front number plate holder/mount maxdude First Generation MINI Exterior 0 Jul 27th, 2004 12:54 PM
Arkon Cup Holder PDA Mount brassd First Generation Interior & Ice 3 Jun 9th, 2004 06:45 PM
Rear Cup Holder used as a Camera Mount Restyle First Generation Interior & Ice 27 May 1st, 2004 09:50 AM
