Auto AC climate control - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 11th, 2004, 08:35 PM
DarkMiniCooperS's Avatar
MINI crazy!
Send a message via MSN to DarkMiniCooperS
Local Time: 08:07 AM
Canada
Hi motorers!
I have the automatic climate control in my MCS and I love it but I actually almost never leave it on the Auto mode with A/C on...
I was wondering if many of those of you who got this option leave it on the Auto mode with the A/C on all the time...
2012 Countryman S All4 - Light White, Sunroof, Premium & Cold packages, Xenons, Adaptive lights, and lots of fun!!
Old May 11th, 2004, 08:40 PM
snuffy's Avatar
meow mini2 meow
Send a message via MSN to snuffy
Local Time: 12:07 PM
United Kingdom View snuffy's Solid Black & White 1st Gen MINI Cooper Profile
I leave the a/c off unless it's hot or the car is misting up because it's raining
Old May 11th, 2004, 08:41 PM
Mini_Blake's Avatar
MINI2 lurker
Send a message via ICQ to Mini_Blake Send a message via MSN to Mini_Blake
depends on the climate that you are in, Im currently in florida, and could see a need for it here, but back home in england, where the weather isnt as predictable I hardly ever use my AC.
+ No AC == better fuel consumption and a more responsive car.
Old May 11th, 2004, 08:42 PM
dcfkan's Avatar
In exile, down SOUTH!
Local Time: 01:07 PM
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile
I set mine at 16 deg C and leave it on all the time, there are threads about whether that is a good thing to do or not, worth performing a search using "dietcokeplease" under username and "air con" as key words in a post
DK :apple:
Old May 11th, 2004, 08:57 PM
andyupnorth's Avatar
It will affect performance slightly and fuel consumption will be slightly more, however the emphasis is on the slightly.
"Do try to keep up Nigel!"
Old May 11th, 2004, 09:06 PM
MINI crazy!
Canada
I usually leave it at 21C or 22C and play with the level (+ -). I rarely set it to Auto without the A/C and almost never leave it to Auto with the A/C on...
Old May 11th, 2004, 09:56 PM
Windshadow's Avatar
United States Male View Windshadow's British Racing Green & White 1st Gen MINI Cooper S Profile
mine has been set to 66F AC on since I got it... I have used Recirc a few times but other than that I have it doing its automatic thing all the time
S BRG/W Randolph 3 PAC NAV
Mid Coast Maine, U.S.A.
Old May 11th, 2004, 10:42 PM
ALD0's Avatar
Im new to the Auto Air con-And I have to say it can me annoying sometimes!!
I find just turning it on manually on 2 bars when it's hot-otherwise it's noisy trying to cool the car down all the time-And also affecting performance!!!!!!!
Old May 11th, 2004, 10:50 PM
Damo's Avatar
Lights are on but...
Send a message via MSN to Damo
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile View Damo's Classified Ads
I leave mine on Auto, cept when I'm demisting. I just asjust the temperature.
Its very clever if you leave it to do its job properly and just ajust the temp if your hot/cold.
Old May 12th, 2004, 08:29 PM
ALD0's Avatar
You can have it on Auto-set your desired temp then press the button -i.e window-face or feet-then it will heat/cool accordingly
But you can over ride it and use it as Manual Air con aswell.
Old May 12th, 2004, 08:57 PM
ALD0's Avatar
Yep-Though if you have the Quick clear windscreen it turns on aswell when you press the Wndow Button.-Which can be annoying.
Old May 12th, 2004, 09:27 PM
jhbuining's Avatar
MINI2 Member
Local Time: 02:07 PM
Netherlands Male View jhbuining's Dark Silver & Black 1st Gen MINI Cooper S Profile
I've got mine set to Auto all of the time, at 21C-22C. When the AC isn't needed for cooling or demisting that's switched off, to save some fuel. This is more on a seasonal than on on a daily basis though... The only slightly annoying thing is that auto fan speed seems to try to simulate the air flow of a higway cruise, even when you're standing still. The effect on the temperature and humidity etc. are great, but it's kind of noisy when driving at low speeds. The automatic selection of which outlets to use works quite well, using windows+feet for heating in the majority of cases, and chest for cooling, which happens to be my favorite setting. If there were one design issue, it would be the location of the temperature sensors. Whenever my stereo head-unit runs hot (Sony CDX-MP80) it seems to affect the sensor reading by several degrees. This effect takes quite a long time to develop, but I do need to turn the control up by a degree or two after about half an hour. All in all, I would buy the auto a/c option again for my next MINI (who am I kidding..., the next one probably will be)
2004 Cooper S, DS/B, LB/PB, DSC, ITS, MFSW, ... (all options except for ICE, SatNav, Xenon's and PDC).
To add an auto climate control to a non-auto climate mini pcho First Generation Interior & Ice 5 May 20th, 2004 10:40 PM
Auto Climate control fault eliseman First Generation Faults & Fixes 0 Feb 17th, 2004 09:21 AM
No Auto Climate Control TDBearCT First Generation Faults & Fixes 6 Oct 1st, 2003 04:01 PM
auto climate control bluesmini First Generation Interior & Ice 10 Aug 14th, 2003 09:30 PM
Auto Climate Control ruthie First Generation Interior & Ice 1 Apr 3rd, 2003 06:09 AM
