Factory Alarm - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 7th, 2004, 08:51 PM
Local Time: 06:52 AM
Question Factory Alarm
I just got my factory alarm installed by my local dealership. I am sure it works great but I can't set it off to find out. I don't want to learn if it works when it gets broken into. Is there a security setting on these things? Most car alarm systems can be programed for high or low intensity. I want mine med-high, especially with all the mods i've done.
HELP
Old Jun 8th, 2004, 03:50 AM
Local Time: 03:52 PM
Netherlands View JBOO's Solid Black & White 1st Gen MINI Cooper S Profile
Why can't you test it out? I rolled my windows down and licked the car. Waited a few minutes, then stuck my hands inside the window. IT WORKED!
Not sure about the question of settings though.
Digi-Tec MCS Gone
Life without a supercharger is boring
Old Jun 8th, 2004, 04:12 AM
scooterboy's Avatar
Local Time: 11:52 AM
United States View scooterboy's Indi Blue & Black 1st Gen MINI Cooper Profile
Quote: Originally Posted by JBOO
Why can't you test it out? I rolled my windows down and licked the car. .
So you tested the saliva detector - what about the rest?
Old Jun 8th, 2004, 06:01 AM
scooperman_uk's Avatar
almost 59k
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile
2 ways to test it that MINI dealer used when my system had to be replaced.
1) volumetric internal alarm - get in car set alarm, sit still and then wave arms - WHOOOOOWHOOOOO etc
2) tilt sensor alarm - set alarm and then jack the car up, soon as one of the wheels is off the deck - WHOOOOOWHOOOO
Old Jun 8th, 2004, 06:02 AM
almost 59k
dont think theres a sensitivity settings, however the tilt alarm can be disabled (see your owners book) for going on ferries. etc.
Old Jun 8th, 2004, 11:46 AM
mdsbrain's Avatar
Send a message via ICQ to mdsbrain Send a message via AIM to mdsbrain Send a message via MSN to mdsbrain Send a message via Yahoo to mdsbrain
Local Time: 10:52 AM
Yes there is a small box attached to the inside roof which is a motion sensor.
Old Jun 8th, 2004, 02:35 PM
Question
Great......sit inside the car and watch it go off. I am trying to prevent from someone getting this far. I want it to go off when thye pull on the handle or jimmy the lock. Anuways, thanks for the tips. i still am looking for a way to put the alarm settings on high. Someone has to know out there.
Old Jun 10th, 2004, 06:33 PM
miniman marshall's Avatar
Local Time: 07:52 AM
Canada
Does the alarm go off when you try and open the locked doors or the hatch??
Old Jun 10th, 2004, 06:40 PM
dcfkan's Avatar
In exile, down SOUTH!
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile
Sit inside the car, lock it using the remote, and sneeze or jiggle about - that will set it off
In order to open locked doors and hatch, you must first disable the alarm.
You CAN open a locked door by using the key in the lock, however, you only have 20s or so (not sure if this is the correct interval, have not timed it) to disable the alarm by putting the key in the ignition.
I think you may need to put the key in the ignition as well as turn it to the first notch in order to diable the alarm using the key - this is what I do when I use the spare key which is not a remote key. Someone should check and verify if this is necessary
DK :apple:
Old Jun 10th, 2004, 06:43 PM
dcfkan's Avatar
The tilt alarm can be disabled by pressing the lock button twice in quick succession - you can see the LED changes from steady blink to intermitent blink
DK :apple:
Factory Alarm dogpaddler First Generation MINI Convertible 2 Feb 21st, 2006 11:01 PM
Factory Alarm 770 KOF First Generation Interior & Ice 1 Nov 10th, 2004 04:03 PM
Factory Alarm or After Market Alarm? prs General Discussion 5 May 7th, 2003 01:31 AM
Factory Alarm dldds First Generation MINI Cooper S 13 Jan 29th, 2003 06:14 PM
Factory Alarm Help!!!!!!!!!!!!!!!!!!!!!!!! dinger First Generation Interior & Ice 2 Aug 15th, 2002 07:27 PM
