Should my vents always blow? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 9th, 2004, 04:02 PM
stephenfroude's Avatar
Local Time: 12:08 PM
United Kingdom Male View stephenfroude's Indi Blue & White 1st Gen MINI Cooper Profile
Question Should my vents always blow?
I've noticed that the air vents in my '04 Cooper blow air even when the fan speed is set to 0 (there doesn't seem to much of a difference between the air flow when set to 0 and when set to 1).
Is this right? Do I really have to close all the vent to stop any air blowing into the car?
Old Jun 9th, 2004, 04:16 PM
Local Time: 08:08 AM
Your vents will allow air flow caused by the movement of the car, to avoid you getting stuffy and suffocated.
You could stop driving, then the air should not "blow"
You could adjust the air flow direction to the screen or feet, where you won't notice it so much.
You could press the "recirc" button to shut the outside air intakes, but then you will get stale air in the car after a while.
Old Jun 9th, 2004, 04:20 PM
I'd rather get wind burn than stop driving.
Thanks for you help.
Old Jun 9th, 2004, 04:32 PM
Local Time: 01:08 PM
United Kingdom View MINIALEX's Dark Silver & White 1st Gen MINI Cooper S Profile
Mine does this - and ive noticed that if the dial is set at hot when you turn it off the air that comes through is hot which i find a little annoying
Cometh the Hour, Cometh the MINI
Old Jun 9th, 2004, 08:20 PM
devilsushi2000's Avatar
Send a message via MSN to devilsushi2000
England View devilsushi2000's Classified Ads
I have found the same as minialex
Old Jun 9th, 2004, 08:30 PM
Phenom's Avatar
Vercetti Clan
United Kingdom View Phenom's Classified Ads
I have found the meaning of life also
Old Jun 9th, 2004, 08:59 PM
racer-x's Avatar
Local Time: 05:08 AM
United States View racer-x's Dark Silver & Black 1st Gen MINI Cooper S Profile View racer-x's MINI Features Album
And does it Blow, Phenom?
Old Jun 9th, 2004, 11:32 PM
obehave's Avatar
Mini Mod
That's exactly what it should do.
More cars are doing this. It's a safety feature. Reduces the possibility of CO poisoning. And if you've noticed there's usually air blowing on the windscreen as well. Also a safety feature. If something should go wrong with the fan or controls the default will always allow you to get fresh air and allow you to defrost/defog the window. Not doing so could make driving a bit of a challenge.
Old Jun 9th, 2004, 11:41 PM
Phenom's Avatar
Vercetti Clan
racer-x, No dude it sucks!
On topic for a moment, I havent really noticed this... but then I dont really notice much tbh!
Old Jul 12th, 2004, 06:20 PM
RedWithWhiteStripes's Avatar
Scotland View RedWithWhiteStripes's Chili Red & White 1st Gen MINI Cooper Profile
All you need to do is turn the dial to blow onto the windscreen, and all the air will be diverted away from you.
Old Jul 12th, 2004, 06:30 PM
Ian Clark's Avatar
Send a message via MSN to Ian Clark
United Kingdom View Ian Clark's Pure Silver & Black 1st Gen MINI Cooper Profile
Either that or at the floor.
I find it quite nice to have it directed half at the feet and half at the face setting with the blowers angled towards the doors
Fresh air in the car but not blowing directly at your face
Old Jul 13th, 2004, 09:21 AM
ChrisBray's Avatar
If you turn the fan switch to off, you are just turning the fan off. Air is still flowing over the heater matrix as you are driving, so will come out hot.
Dink Dank Doo!
Old Jul 13th, 2004, 09:31 AM
This is interesting. I was given a 3 series courtesy car a couple of weeks ago and no air came through the vents when the fan was switched off.
I'm pretty sure this was the case for my previous car too.
Doesn't really bother me because I usually have the fan set to 1. Just wanted to make sure my car was working properly.
Old Jul 14th, 2004, 01:46 PM
Ian Clark's Avatar
I had a focus before the MINI and all though the amount of air that got through was less, it still got through even if the fans were turned off
  #15 (permalink)
Old Jul 15th, 2004, 08:48 AM
URU's Avatar
URU
United Kingdom Male View URU's Dark Silver & White 1st Gen MINI Cooper S Profile View URU's Classified Ads
turning the fans off on the dash just stops the fans. if u want to stop the air flow all together, turn the centre of the 4 air ducts on the dash.
STOLEN AC SCHNIZTER 17" MINI ALLOYS
plz pm me if you hear/see anything (read more HERE)
I had a blow-out today AtomicKiwi General Discussion 20 May 13th, 2004 07:31 AM
Blow out!!! oreokid First Generation MINI Cooper 8 Jan 31st, 2004 06:28 PM
Problems with the Foam under the Cowl Vents (twin vents near wiper arms) Ginger First Generation Faults & Fixes 12 Oct 29th, 2002 04:31 AM
You're Only Supposed to Blow s_and_m UK & Ireland Discussion & Event Planning 0 Sep 21st, 2002 05:36 PM
