05 door handle/arm rest retrofit - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 31st, 2004, 09:59 PM
Local Time: 01:11 PM
Question 05 door handle/arm rest retrofit
I noticed on mini.com and in the advertising literature that the arm rest portion of the interior door handle has been redesigned with more ergonomic consideration. Has anyone made a comfort comparison. More importantly, does anyone know if the new door handle will fit in the door or pre-05 models? Probably a question better addressed to the dealer, but I haven't queried them yet. Thanks.
Old Aug 1st, 2004, 09:34 AM
Paul's Avatar
MINI2 No.1
Local Time: 12:11 PM
England Male
Having spent considerable time and miles in an '05 model interior and obviously many more in the "old" version, overall I much prefer the old design. The new design does work slightly better as an arm rest, but seeing as I drive a manual I don't really rest my outside arm, as the other arm is called into action more often to change gear. On the storage side, it's a pain in the backside, once you put something in there, it's a pain to get out. It looks a bit better because of the curves, but overall, I think it's a bad move. But those who like to drive one armed might disagree.
Old Aug 1st, 2004, 11:12 AM
Paul's Avatar
MINI2 No.1
England Male
I also dont see any reason you couldn't retro fit it if you want to.
Old Aug 6th, 2004, 03:53 AM
MINI2 Sponsor
I tried to remove that part and it is heat staked on to the door insert from what I could see. And the oval insert is heat staked to the door panel...so you would have to drill out the plastic and when remounting you would then have to rig it a bit...
Aaron Cornaby : Head Motorer
Door Arm Rest MikeTango75 Maintenance & MINI Care 3 Aug 8th, 2005 05:14 PM
How do i take the leather arm rest off my door cards? .Boyracer. First Generation Interior & Ice 1 Aug 6th, 2005 08:06 PM
How about an arm rest like this? averyocooper First Generation Interior & Ice 3 Apr 28th, 2004 12:31 AM
Arm Rest Bonnie Scotland First Generation Interior & Ice 27 May 30th, 2003 10:42 PM
