HK enabler - pic - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 31st, 2004, 08:50 PM
mikeythemini's Avatar
Local Time: 01:12 PM
DIY HK enabler - pic
Iv'e had a few mails & calls asking what the HK enabler looks like so here it is
This is the version with the mode select switch
Name:	hk enabler.JPG
Old Sep 1st, 2004, 06:29 PM
CurtP's Avatar
Local Time: 07:12 AM
United States View CurtP's Pepper White & Black 1st Gen MINI Cooper S Profile View CurtP's Classified Ads
How does one know what "mode" they're in when using that bit of kit?
Old Sep 1st, 2004, 06:46 PM
Local Time: 08:12 AM
You need to listen to the sound and recognize the mode ... certain modes (eg: instrumental) are very easy to recognize to then you know where "in the list" you are.
In truth, I generally don't change the mode once I have selected one I like - and actually I am not even certain what mode I am currently listening in, but I like it.
You can simply press the button repeatedly till you get a good sound, and leave it at that - maybe it does not even matter which "mode" is selected, so long as you like the result?
Feedback - displays, or even LEDs - would add significantly to cost and complexity of installation. As Mikey says, you can order a version with no button and no way to change the "mode" - it is set up the way it will always be. Most aftermarket amps are this way, relying only on the head unit controls ...
Old Sep 3rd, 2004, 08:13 AM
xnetco's Avatar
United Kingdom View xnetco's Indi Blue & Body Color 1st Gen MINI Cooper Profile
Sorry guys, what does this unit actually do?
Old Sep 4th, 2004, 06:45 PM
speacock's Avatar
Local Time: 05:12 AM
United States View speacock's Dark Silver & Black 1st Gen MINI Cooper S Profile
The HK sound system for the MINI has an amplifier that is controlled digitally by the stock head unit. If you remove the head unit the HK amp stops working.
The adapter sends the necessary wake-up/setup I-bus codes to amp allowing you to install an aftermarket head unit.
Sean
DS/B JCW MCS S1920
My experience with Harmon Kardon, HK Enabler, and aftermarket stereo. O2OnFire First Generation Interior & Ice 26 Sep 24th, 2008 09:08 AM
Fitted a new Stereo with H/K Enabler now have Hissing!? Gavin1980 First Generation Interior & Ice 4 Jun 11th, 2007 08:05 PM
HK Enabler Users Feedback MadisonMini First Generation Interior & Ice 1 Sep 26th, 2005 01:59 AM
Pic Help! Phil321 General Discussion 1 Aug 17th, 2003 09:40 PM
Pic of red 'S' from Long Beach MINI meet <pic by tUNINGwERKS> DDD First Generation MINI Cooper S 3 Oct 22nd, 2002 08:19 AM
