| 2005 door panel removal I thought this might help a few who need to remove their door cards on the revised 2004 models. First of start with the guide found here . This will provide the basics. The guide mentions 4 Torx screws. One of these is now hidden under the bolster attached to the grab rail. To remove it insert a flat blade screw driver in from the front. This will press down on a post on the bolster and will allow you to slide it forwards. Be very carefully not to mark the silver trim. This finish is already very thin and does not take much to scratch. Use a cloth behind the screwdriver or mask the area off with some tape first. In the pictures below you will notice that I have not used a screwdriver but a special trim removal tool. It is great for popping the trim clips around the door, although the Mini ones do tend to pull off just fine without breaking. This is a generic one by made by a company called Draper. I purchased from CPC . It costs £3.13 and saves on a lot of scratching and busted clips. It has a tapered end to ease under door cards etc. and squeezes around the clips making it easier to prise off. If you remove to door cards a lot or work on other cars you will find this a good investment The 1st pic shows where to insert your tool, ooh err and the other shows bolster removed and the clip that you are trying to release.Hope this helps. |
| Looks like the site is having a bit of an off as I can't post me pic's here. I have put them in my gallery. However the thumbnails did not render so click on the images to see them. This shot shows the clip being released and the next shows the armrest removed and the hole of the third (hidden) screw. |
| I was working on the driver's side door. These pix are for the passenger side. Insert your screwdriver from the front of the armrest (the engine side not from the trunk side). I spent a few minutes putting the screwdriver in the wrong end. Once I put the screw driver in the correct end the arm rest came right off. |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-interior-ice/70301-2005-door-panel-removal.html | ||||
| MINI COOPER :: North American Motoring - '05 MINI Door Panel Removal? | This thread | Refback | Jan 15th, 2009 01:52 PM | |
| Door panel removal help please. | jmardy | First Generation Interior & Ice | 8 | Apr 3rd, 2007 10:33 PM |
| door panel removal problem | Adam cook | First Generation Interior & Ice | 3 | Dec 11th, 2006 08:04 PM |
| 2005 Door Panel Removal | Enlightened v2 | First Generation Interior & Ice | 5 | Feb 25th, 2005 02:23 PM |
| Removal of door panel with HK system | GTT 280 | First Generation Interior & Ice | 7 | Mar 28th, 2003 10:01 AM |
| door panel/card removal pic plz | bcbeme | First Generation Interior & Ice | 2 | Sep 1st, 2002 02:27 PM |
