Wiring an Amp - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 12th, 2005, 04:51 PM
Crouchy's Avatar
Doncaster MINI Register
Local Time: 01:26 PM
England Male
Wiring an Amp
Hi im new to this so please excuse me. I tried to fit my amp today but i didnt no where to run the power wire. I got it to the front of the cabin easy enough but can anyone tell me how to get it from the footwell to the battery in the engine bay. Some of you will probably be laughing at me right now but like i said, im new to this and therefore a complete novice. Any help will be much appreciated. Thanks.
Old Jan 14th, 2005, 06:51 AM
Local Time: 04:26 AM
I just finished this, and found that the process is fairly easy. I am in the U.S., so my instructions are for the driver side being on the left side of the car. I have not seen a car from the U.K. with the alternate setup yet, so I'm not sure if this works, but here's what I did. On the passenger side, I pulled up the carpet on the footwell pretty far, and there is an indentation about half way across toward the center of the car. I used a step bit (it allows a perfect circle to be drilled at the exact size you need) and drilled a hole through this section. If done right, it should come out beneath the black plastic covered area that is toward the back of the engine compartment. I also put a 4 gauge wire grommet in the hole I drilled so that the wire would not rub against the cut metal and short out. The grommets are very cheap and you can get them from most stereo shops that do quality installs. Once the wire is through the firewall, there is a grommet at the bottom of the compartment that the black plastic forms in the back of the engine compartment. Just run up through that, as it already has a hole for water to drain through. I'm not sure if the battery is in a different location on the US cars, but for me, if you are standing in front of the engine, it is on the right side. My drill hole was on the left side, so I ran up through the left black plastic compartment and then ran the wire through the back into the other black plastic compartment, which works really nicely, and then tapped the battery on the outside connector (not the actual post). If you tap the outside connector, get a good quality terminal that can be bent 90 degrees (I had a 4 gauge terminal from Monster Cable and had to heat it over the stove before I could bend it). This will allow the plastic cover to snap into place without being blocked by your terminal and wire, and will be waterproof (for the most part, as much as Mini made it).
Amp wiring help Minione7 First Generation Interior & Ice 5 Apr 2nd, 2008 11:57 AM
Wiring an amp for sub woofer Volte First Generation Interior & Ice 7 Jul 22nd, 2007 11:55 PM
Best re-wiring plan for HU->amp, amp->speakers in US '05 MCS? testanley3 First Generation Interior & Ice 4 Feb 10th, 2007 04:03 PM
Sharks Fin wiring & Mobile Phone: Q's & A's perl First Generation Interior & Ice 26 Sep 12th, 2003 06:07 PM
Wiring an amp Dom First Generation Interior & Ice 4 Jan 20th, 2002 06:49 PM
