changer cable convertable - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 25th, 2005, 08:01 AM
Local Time: 01:27 PM
United Kingdom View den123's Classified Ads
United-Kingdom changer cable convertable
hi guys, anyone know where the changer cable is located in the boot on a convertable thanks
Old Jan 25th, 2005, 08:45 AM
Send a message via MSN to ned78
Ireland Male View ned78's Classified Ads
Only by actually looking for it did I find it. It's buried under the plastic on the right hand side, deep inside the foam that's sculpted to the boot shape. You'll need to undo some bolts to get to it.
Owen.
Old Jan 25th, 2005, 09:04 AM
lukeybabe's Avatar
Send a message via MSN to lukeybabe
Local Time: 12:27 PM
I found mine on the drivers side, under the plastic.
I found if you put the back seat down you can just get you hand in their, it is two black flat plugs taped to the main loom running underneath the foam.
Happy hunting!!!
Old Jan 25th, 2005, 10:27 AM
cable
thanks guys
Old Jan 25th, 2005, 02:30 PM
United-Kingdom help please
have found 2 cables at the drivers side at the back but they seem to be stuck is there 2 cables for the changer black ones whats the best way to get them free if thats them i dont want to pull them just incase its not the changer cables thanks den
Old Jan 26th, 2005, 07:16 AM
lukeybabe's Avatar
There should be two small black plugs
Mine were taped down to the main loom with the felt tape they warp around everything, I just un-wrapped or cut the felt tape back enough to get the plugs free.
From memory they are the only loose plugs round there, so they will be the ones, just check they look the same as whats on the bottom of your autochanger if you are un-sure.
Old Jan 26th, 2005, 08:22 AM
cable
thanks guys will try again
cd changer cable Coopy First Generation Interior & Ice 4 Mar 5th, 2007 06:23 AM
Routing a CD changer cable malinga First Generation Interior & Ice 7 Jul 4th, 2006 09:11 PM
Ipod AUX cable vs Navi cable (navi has no sound now) Back2DTM First Generation Interior & Ice 6 Oct 21st, 2004 04:44 PM
Changer Cable MINIALEX First Generation Interior & Ice 1 Aug 27th, 2003 08:37 AM
CD Changer Cable Route - non-CD Prep Pritch First Generation Interior & Ice 0 Aug 22nd, 2003 09:42 PM
