passive crossover adjustment for tweeter sensitivity - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 12th, 2005, 09:01 PM
Local Time: 12:07 PM
United States View dami2550's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
I have Focal 165V2 components in the front. Woofers in doors (factory locations), tweeters on dash, cross-facing each seat, meaning passenger's tweeter faces driver and vice versa.
Passive crossovers set for 0dB on woofers and -6dB on tweeters.
I have factory headunit, PAC OEM-2 convert to RCAs, then goes to Rockford Fosgate Punch amp
Problem - tweeters are still too loud. I have tweeters down all the way in the head unit.
Question - is there a EASY way to silent tweeters even more (apart of buying new head unit, mounting it face down or wrapping it in cloth or something like that
Thanks!
Old Apr 13th, 2005, 08:16 AM
tnoy66's Avatar
POP..POPPOP..POP
Local Time: 05:07 PM
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
Try re-positioning the tweeters into the footwell area pointing up towards the rear-view mirror.
Temporarily extend your cables and just try various positions and angles.
Here in th UK we use Blu tac to hold the tweeter in place whilst we try different positions and angles.
Not sure if you can get it over there, and before you ask what it is........http://www.brainyencyclopedia.com/en...l/blu_tac.html
Old Apr 13th, 2005, 07:39 PM
OK, nevermind - found the real problem
And, since I'm using factory head unint and PAC OEM-2 to convert to "unamplified" signal, that's where the problem begins. Sounds either that OEM-2 has bad "conversion" or headunit puts out ****** signal. I switched OEM-2 input from low power to high power, it's somewhat better, still distorts too much.
And, I have to mount woofers better because not much bass in front, only mid-range and highs.
Worst comes to worst - replace the headunit with that new Alpine 9855, that's gotta fix it then.
Passive iPod Nano Second Generation Cradles el_corpo First Generation Interior & Ice 1 Apr 14th, 2007 12:39 AM
H/K and alpine crossover boothy First Generation Interior & Ice 1 May 5th, 2006 06:25 PM
Infinity 5000 Cs, Tweeter-crossover Setup JCW COOP 350 First Generation Interior & Ice 0 Jun 28th, 2004 04:26 PM
Appeals court rules passive pressure monitors are not good enough HarryHBMCC MINI in the Media 6 Aug 28th, 2003 05:50 PM
Wiper Sensitivity Adjustment? tfisher General Discussion 1 Aug 1st, 2003 04:42 PM
