Problem: AUX on / AUX off - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 3rd, 2005, 04:10 PM
uptick's Avatar
MINI2 somebody
Local Time: 12:01 PM
United States View uptick's British Racing Green & White 1st Gen MINI Cooper Profile
Problem: AUX on/AUX off!
I am currently experiencing a problem where the AUX mode on the stock '05 CD headunit (no Harman Kardon) works selectively depending on the source I plug into the AUX input, which was installed by the dealer. AUX mode works fine when I use my iPod connected via the Belkin Auto-charger line-out. It stops working when I plug in my XM SkyFi2 tuner connected via its car dock. For some reason, the headunit consistently and automatically switches out of the AUX mode after 1-2 seconds upon switching the source to the XM tuner, and then it refuses to cycle back to AUX mode (it only gives me radio and CD modes). If I unplug the XM tuner, the AUX mode becomes available again.
As far as I know, there is nothing faulty with the XM tuner, since it works perfectly with the AUX input on my '03 stock headunit (w/HK - in other MINI). I am using the same exact mini-stereo cable with the iPod and the XM tuner; I just switch the source end when I want to go from iPod to XM. Somehow, I suspect the new headunit senses something with the AUX feed and then deactivates the AUX mode when XM is plugged in.
Does anyone know why this is happening?
Old Jun 7th, 2005, 01:54 AM
TheOldMan's Avatar
Get off my lawn!
United States Male View TheOldMan's Solid Black & White 1st Gen MINI Cooper S Profile
You are not alone, I've been having the same problem. Posted on NAM and a few others are have the same issue.
http://www.northamericanmotoring.com...ad.php?t=43063
Hope we can fix this.
--Mark
Old Jul 1st, 2005, 05:27 PM
uptick's Avatar
MINI2 somebody
Upon playing around more with the hook-up, my problem seems to be something to do with the DC power that is feeding the XM Skyfi2 radio. If I keep the AUX cable plugged in and unplug the power to the XM radio (either at the dock jack or at the cigarette outlet) the AUX mode on the headunit STAYS! As soon as I reconnect power to the XM radio, the AUX mode cuts out and disappears as long as the powered-XM radio is plugged in. It does not matter whether the radio is "on" or "off" - as long as the power adapter is plugged into the XM and the XM is plugged into the AUX, my AUX mode will not work. (This is very strange, since this same exact set-up does not affect the AUX mode in my 2003 MINI.)
I also experimented with powering the XM radio using the 'home kit' AC adaptor. When the SkyFi2 is powered by the AC adaptor, there seems to be no problems of the AUX cutting out. AUX mode is selectable on the head unit, and it does not cut out.
So my conclusion is the DC power adaptor may be a source of interference that is causing the AUX to cut out when the XM SkyFi2 is all plugged in. Somehow this interference creeps into the audio path and reaches the head unit via the AUX input. The newer head units may have some circuitry that cuts off the AUX source if it senses a 'dirty' signal being sent in, even though what we hear does not sound 'dirty' at all.
My next experiment turned out to be the solution to this problem. I went to Radio Shack and bought a Ground Loop Isolator (SEE THIS). This device was installed in place of my mini-stereo audio cable, between the XM SkyFi2's line-out and the AUX jack. I also needed a Y-Adaptor (SEE THIS) to convert the mini-stereo jack into RCA jacks to connect to the ground loop isolator. Upon installing this, my AUX mode returned as an available source on the head unit. It also did not cut out again. I believe this device filters or cleans that 'dirty' signal that kept causing the head unit to cut off the AUX source when my XM SkyFi2 was plugged in.
Problem with tha AUX plug tampaguy001 First Generation Faults & Fixes 3 Nov 7th, 2005 11:03 PM
Weird AUX Input problem !!! Aurel First Generation Interior & Ice 7 Sep 2nd, 2005 10:22 AM
Does 2005 HK stereo offer Aux _mode_ or just Aux input Mini4Cathy First Generation Interior & Ice 2 Jul 16th, 2005 03:30 PM
Problem with installing Aux input Fabio First Generation Interior & Ice 12 Nov 5th, 2004 10:22 PM
Aux. Gauges vs. Aux. Audio Input Roberto First Generation Interior & Ice 11 Mar 24th, 2004 04:02 PM
