replacing door grilles and fitting speakers in their place - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 27th, 2005, 09:49 PM
A13EX F Cooper S's Avatar
Send a message via MSN to A13EX F Cooper S
Local Time: 01:33 PM
Has anyone removed the factory fornt speaker grilles and fitted aftermarket speakers in their place so that the performance speaker grilles and speakers are visible?
if you have done can you post any pictures?
also (I know this sounds daft and you'll sya measure it but i dont have car yet) what size speaker will go in the place of the grille but the screw holes caused by fitting the speaker wont be visible if speakers are converted to standard?
any help whatsoever would be great.
thanks.
p.s. stereo system so far is as follows.
Alpine CDA9853R headunit
2x Rockford Fosgate power series 10" subs (t110d2)
1 pair rockford fosgate punch 6x9s (FRC3369)
1x rockford fosgate 1051s amp for subs
2x Rockford Fosgate 150s amps for front and rear speakers
Rockord Fosgate 1farad power cap with blue led display, blue led's and blue led neon built in.
just need to sort the fornt speakers out ready.
Old Jun 27th, 2005, 10:12 PM
:: Jon ::'s Avatar
Scotland Male View :: Jon ::'s Classified Ads
wouldnt mind knowing this too
Old Jun 27th, 2005, 10:34 PM
do you have a mini yourself?
I'd be able to figure it out as soon as i get car but want everything ready for when i get it.
could you get a tape measure out and measure the grill for me if you dont mind.
the grill should overlap the door card itself by about 5mm all the way round. to remove the grille i'm guessing it's just glued in a few spots behind so a small drill bit will get that off easily.
Old Jun 28th, 2005, 12:46 AM
BigGerald's Avatar
Local Time: 06:33 AM
whoa
I think you are going to blow your Mini up with all that.
Old Jun 28th, 2005, 08:33 PM
I got the speakers delivered today they're bloody heavy for 10" thinking more and more now how the F* am i gonna fit it all in..
has anyone done me a favour yet and measured their front grille so I know what size speakers to order?
Old Jun 30th, 2005, 07:26 AM
Axtell's Avatar
Local Time: 04:33 AM
United States View Axtell's Hyper Blue & Black 1st Gen MINI Cooper S Convertible Profile
You can do 6 1/2" component speakers in the front (anything under 2.5" deep should fit), and 6 1/2" coaxials in the rear.
How do you plan on putting 3 amps and a sub box for 2 10 subs in the back? going to be a ton of manipulating...probably have been better off doing a nice 4 channel amp for the highs and a single channel amp for a single sub in the rear.
6x9's aren't going to fit, unless you plan on cutting up a ton of the plastic in the rear.
Old Jul 7th, 2005, 10:55 PM
lastblink182fan's Avatar
mini cooper pilot
uh
ur talking about what? ther are 6 by 9's in the rear. thats whats already there. ....
Old Jul 8th, 2005, 07:53 AM
Yes 6x9's are already there, i will be mounting rockford fosgate items in their place.
the front speakers are the only ones which are going to be on view so therefore need to be the correct size as the rear ones can be made to fit under the interior trim.
Old Jul 8th, 2005, 03:08 PM
mini_macky's Avatar
JL Mini Boombox
Send a message via Yahoo to mini_macky
Local Time: 08:33 PM
Philippines
i currently have JL Audio 6.5" midranges installed in the factory locations. according to my installer, a little trimming was needed, nothing major, for the bigger speakers to fit. better put dynamat on the doors if you're gonna upgrade the door speakers
Old Jul 8th, 2005, 03:34 PM
Yes dynamat is a must i used so much of it in my lupo.
the boot door was full of their expanding foarm, i taped up all the holes and just squirted it in. A little bit of a messy job but it improves sound quality and eliminted all rattles.
Old Jul 8th, 2005, 07:58 PM
SteveM3's Avatar
ah ha. Welcome to the world of Mini strange. The speaker grills are part of the door trim
and not part of the speaker. I doubt if they touch. Removing the grill to put a better looking
one is not so easy as I think it is held in place by adhesive. Plus the new grille won't blend
with the interior. Do what most people do, replace the speaker but leave the grill in place.
My Focals have a 72mm mounting depth and they were a tight squeeze. That's about
2.8 inches so I think the Punch speakers should be fine.
Old Jul 8th, 2005, 08:23 PM
Mike Edwards's Avatar
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Mike Edwards's Classified Ads
What size are the door speakers?
I have some MB Quarts lying around - if they fit it would at least get them out of the way.
BTW, I've discovered that using the BMW iPod adaptor + iPod means that you can turn up the volume to the point where "Blue Monday" makes your chest vibrate (and is still distortion-free).
Given this - is it really worth the effort of the upgrade?
Old Jul 9th, 2005, 05:32 PM
SteveM3's Avatar
Door speakers are 5.25" but you can also fit 6.5". Either way you'll need an adapter as well.
I was surprised at the quality of the OEM speakers but some of us must spend spend
spend so I bought Focals as replacements. Now I wish I had spent more on Genesis
Audiophiles .
Last edited by SteveM3; Jul 11th, 2005 at 08:22 PM. Reason: Mistake in speaker size.
Old Jul 11th, 2005, 01:34 PM
cautionespn's Avatar
Local Time: 08:33 AM
Quote: Originally Posted by SteveM3
Door speakers are 5.25" but you can also fit 6". Either way you'll need an adapter as well.
Audiophiles .
Ahhh crap I think I bought the wrong speakers off eBay. A/D/S 1688s 6.5" which i wanted to put in the doors (comes with the separate tweeters). Oh well only cost me $80US and I can probably re-sell them for a similar price. I guess I'll have to keep looking. I'm a big fan od A/D/S so i was happy to find these available (they are an older model but still NIB). Crap
  #15 (permalink)
Old Jul 11th, 2005, 04:29 PM
mini_macky's Avatar
JL Mini Boombox
Philippines
don't re-sell them just yet. my Mini has 6.5" midranges in the doors, minor trimming was the trick (according to my installer) check out my door install. had stock tweeters replaced & mid-bass on kick-panels
Name:	Copy 1 of Image.jpg
Which is the live wire in the front and back speakers as im fitting new speakers fozworth First Generation Interior & Ice 3 Feb 10th, 2009 10:04 AM
Replacing Rear Speakers Gary90 First Generation Interior & Ice 6 May 24th, 2007 05:59 PM
Replacing rear speakers djwoody First Generation Interior & Ice 18 Aug 29th, 2006 12:00 PM
Replacing factory speakers, looking for the DIY's SSJ First Generation Interior & Ice 4 Oct 14th, 2005 09:58 AM
Replacing main front door speaker with non-component speakers beebleb First Generation Interior & Ice 5 May 28th, 2005 01:51 PM
