H/K Speaker Upgrade - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 31st, 2005, 03:59 AM
Local Time: 07:34 AM
H/K Speaker Upgrade
Ok, im having a problem with my h/k speakers blowing. The front ones...... Anyway, the dealer has replaced them, oh, were on like the 6th time. So, i have decided to take matters into my own hands. I do NOT want anything to screw up my sound quality. I want a direct replacement speaker with no extra wiring, or amps, or drilling, or anything, that has the same sound quality, of the H/K speakers, when they are not blown. I want the quality to be better, and for them to be able to withstand what the amp is putting out. Something that the stock speakers obviously cannot do.
Wow, that post sounds kinda demanding. I saw were someone else was looking for the same thing, but back in 03. He/she did not get the answer i wanted.
Soooo...... Can anyone help?????
Old Aug 1st, 2005, 01:16 AM
Ehh????
Old Aug 1st, 2005, 02:01 AM
Local Time: 08:34 AM
i am pretty sure bmw matched the speakers correctly to how many watts the amp is putting out. i highly doubt replacing the speakers will fix your problem, especially if it has happened six times already. it sounds like there is something else causing your problem.
time to find that amp and start checking it over. i don't know anything about the amp used in the hk system on the mini, but if there is a gain setting and it is set incorrectly causing clipping at high volume that could very well be your problem.
Old Aug 1st, 2005, 10:18 PM
L13 Cooper's Avatar
Astro
Send a message via MSN to L13 Cooper
Local Time: 01:34 PM
United Kingdom View L13 Cooper's Astro Black & White 1st Gen MINI Cooper Profile
ive got an HK system and ive added another amp just to run a sub, and my system has been going for 9momths now and its spent a lot of time at full volume,
The HK speakers for me are fine
Old Aug 5th, 2005, 01:24 AM
Send a message via AIM to tfiedler Send a message via Yahoo to tfiedler
Hey, how did you run your second amp? Did you have to use speaker level input for it or does the factory HK amp have line level outputs?
-Todd
Old Aug 5th, 2005, 01:34 AM
stephenjc's Avatar
Local Time: 06:34 AM
United States View stephenjc's Electric Blue & White 1st Gen MINI Cooper S Profile
-Todd
I would like to know this too. I was understanding that this was a near impossible task. Also where did you put the amp?
Old Aug 5th, 2005, 02:43 AM
Moskito's Avatar
Germany
I was not even remotely considering to get HK upgrade in my MINI, because I think the HK unit in my MCoupe pretty much sucks. The mid range speakers in the ceiling blew several times and because HK does stuff different and runs them on 3ohm, no other speakers can replace them "correctly".
An Audio guy who looked at the HK speakers called the cardboard "backing" stuff absolutely cheap and not worthy.
But I guess, to each their own. I am glad you guys love your HK stuff.
H
Old Aug 5th, 2005, 01:14 PM
jwardell's Avatar
Send a message via AIM to jwardell Send a message via Skype™ to jwardell
United States Male View jwardell's Solid Black & White 1st Gen MINI Cooper S Profile
I'm willing to bet your HK speakers are not blowing at all. It is a very common issue where the speaker grill and door panels vibrate with HK MINIs. It sounds like a blown speaker. Except it will even happen at lower volumes. If you push on the door panel next to the speaker does it stop? The solution is to simply put some felt between the door panel and the door, as detailed on my site below. Hundreds have done this and the problem has disappeared. The speakers themselves are just fine.
Old Aug 8th, 2005, 02:38 AM
How much?
Yeah, they are blowing.... The dealer would not have replaced them for one, they showed it to me, and i have fixed all of my former rattles and have put in a boat load of dynamat.
Speaker only upgrade - please help agi First Generation Interior & Ice 4 Apr 8th, 2005 06:50 PM
Speaker upgrade question Nick-o First Generation Interior & Ice 1 Mar 1st, 2004 04:32 PM
Speaker upgrade for H/K - Help? Corn On The Cob First Generation Interior & Ice 2 Aug 19th, 2003 11:50 PM
Has anyone done a speaker only upgrade? jfelix First Generation Interior & Ice 1 Jul 6th, 2003 02:30 AM
Just a speaker upgrade? Tom F. First Generation Interior & Ice 6 Jan 9th, 2003 07:41 PM
