Weird AUX Input problem !!! - MINI Cooper Forum
First Generation Interior & Ice
post #1 of 8 (permalink) Old Aug 28th, 2005, 03:52 PM Thread Starter
Aurel's Avatar
Local Time: 01:09 AM
United States Male View Aurel's Hot Chocolate & Silver 2nd Gen MINI Cooper Clubman Profile
ok, some weird thing developed literally overnight with the AUX input ... so the day i installed it (this past Friday) I was using the MP3 player no problem ... for hours ...
I come out to the car yesterday and the radio does not go into AUX mode!?!?!? ... I remove the panel and jiggle the wire and the AUX mode appears when it wants to .... but then when I press play on the MP3 player ... it kicks into FM mode !?!!?? ... and the AUX mode is gone again.
Few hours pass and I am driving ... no AUX mode. Then I try it again ... hey, there is the AUX mode again!!! Try playing the MP3 player ... soon as I hit play ... goes to FM mode.
This is really strange and not sure how the heck this happened literally overnight with the car parked.
Might be a short somewhere, at least this is what I am thinking.
Anyone experience this weird phenomenon before?
Aurel is offline
post #2 of 8 (permalink) Old Aug 28th, 2005, 08:19 PM
Domestic Motor Pool Chief
Oldpaint's Avatar
United States Male View Oldpaint's British Racing Green & White 1st Gen MINI Cooper S Profile
I would not just jiggle the wire but remove the whole plug from the rear of the head unit and then reattach it. Maybe its not firmly seated. If so the overnight drop in temp might be enough to break the contact. Anyway doing this doesn't cost anything so its a first step.
everything you know is wrong gnorw si wonk uoy gnihtyreve
Driven on the Arctic Ocean February 2012
Oldpaint is offline
post #3 of 8 (permalink) Old Aug 28th, 2005, 10:01 PM
TheOfficeMaven's Avatar
Local Time: 10:09 PM
United States View TheOfficeMaven's Hyper Blue & Black 1st Gen MINI Cooper S Profile
It's a bug in the head unit I believe. It's a common problem with the AUX input (mine does it too). You need to add in a grounding loop and that will fix the problem. Here are some other threads about the problem (MINI2 & NAM):
Problem AUX on - AUX off
electronic genius needed....aux input question
Need some Aux - ground loop help
Aux keep cutting out
Aux Input installed! (pics)
TheOfficeMaven is offline
post #4 of 8 (permalink) Old Aug 31st, 2005, 10:30 PM Thread Starter
Aurel's Avatar
Thanks for the tips so far ...
I did go ahead and buy that ground loop isolator and it did not help at all. Tried 2 different MP3 players with the cable ... some worked for a few minutes, but eventually all cut out.
I have a feeling it could be a bad cable at this point .. so i am having it exchanged from the dealer. will see if that helps.
I know for sure the MP3 player is ok ... will try the new cable ... and if that does not help ... well
Aurel is offline
post #5 of 8 (permalink) Old Aug 31st, 2005, 10:43 PM
Goin to fast to look back
harveyjoseph's Avatar
United States View harveyjoseph's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Exactly the issue that I had and the ground loop isolator solved the issue. You can get one from Radio Shack.
cheers
harveyjoseph's Webpage
JCW 210 Equipped
harveyjoseph is offline
post #6 of 8 (permalink) Old Sep 1st, 2005, 03:15 AM Thread Starter
Aurel's Avatar
cheers
like I mentioned in my previous post ... I did purchase the Ground Loop Isolator but it did not help at all.
looks like a bad wire at this point.
Aurel is offline
post #7 of 8 (permalink) Old Sep 1st, 2005, 06:10 PM
Hmm...
You're the first one I've heard of where the ground loop isolater didn't actually fix the problem. I too thought that I had a bad cable at first and I returned mine to the dealer. They replaced it but the new one still had the cutting out problem with the radio's Aux mode. The only way I could correct the problem was using the ground loop isolater from RadioShack.
Weird...
BTW, if I plug my MP3 player's cable into the Aux input only half way or so (to where it still gives stereo sound), that seems to correct the problem for me as well. However, I can't get it to stay like that for long as it eventually pops off.
Lastly, it seems that the problem stems from having your MP3 player plugged in. Does it still happen to you if you run it directly from the player's battery?
post #8 of 8 (permalink) Old Sep 2nd, 2005, 10:22 AM Thread Starter
Aurel's Avatar
the players I have tried it with, ONLY run on battery! ...
Aurel is offline
Aux input ipod Rossi rose General Discussion 4 Apr 15th, 2014 10:22 AM
Weird starting problem / FUEL PUMP, FILTER ? Schakal General Discussion 0 Oct 31st, 2013 10:55 AM
Aux input volume levels 07reg - R52 Welshrock First Generation Interior & Ice 1 Jul 12th, 2013 09:34 PM
Aux input interference help Cheesegeezer First Generation Interior & Ice 4 Feb 11th, 2013 04:23 AM
Weird Starting Problem - Electrical, Lock or Computer Maybe? Mrelia First Generation Faults & Fixes 4 Aug 18th, 2012 02:46 PM
