A Question for Mikey! Mike, I've got an aftermarket Video interface to feed into my standard SatNav system.....at the moment it's fed on a permanent live because otherwise the mini logo no longer displays on the screen unless the unit has power. My basic question is whether or not there is a 12v line that goes live as soon as you unlock the car on the remote fob and then stays live until you lock the car again? I'm assuming the SatNav gets it's signal from the canbus to start but I'm not aware of an interface that will give me that capability? What do you reckon? Obviously, anyone else who may have an answer please feel free to pipe up as well! Cheers, Tom... |
| You might want to ask Mike Craven, who posted the terrific MINI Video Input article in www.motoringfile.com -- I don't recall him talking about such a 12v feed. I think you're right that the Nav system uses a 12v line that's always available, and detects the key in the ignition from a message on the I-BUS or the K-BUS. Mike uses a 12v line that's on while the car is turned on and the 12v line from the reverse lights, and added two inexpensive Radio Shack relays to enable a rearview camera automatically when in reverse, and a composite video input when he flips a switch. |
| Thanks for the reply Mike....would I be able to buy some bits from you (I've been waiting before I order my Sharkfin GSM extension cable!) and would you be able to give me an idea where to pick up the various cables I need to splice into? Cheers, Tom... |
| OT to the TheOfficeMaven: did you receive the PM I sent to you on NAM? I wanted to get your opinion on rear camera solutions for the MINI. I probably should have posted it as a thread because there may be useful information for others. |
| Nope....not the same problem for me at all....All I need is a feed that goes 'live' when I unlock the car via the remote as if I have it connected as it is at the moment the thing is permanently live and it drains the battery! I want it to work this way as I still want to be able to see the Mini logo on the display when I open the door! Do I really need to....absolutely not! BUT do I want to.....too right! So what do you reckon Mike? Cheers, Tom... |
| Hi Tom, I'm sorry to hear that your problem isn't related to the AUX input as mine was. Alas, I'm afraid that I don't have a solution for you on this one. All I can say is that something having to do with your aftermarket video input must be feeding a singnal to the MINI's K-Bus which in turn is what's causing the factory sat nav to remain active or in standby mode (you won't see the MINI logo on the nav display until the nav computer spins down into sleep mode and then awakes back from it). It is weird that when you take away the power from your video input the problem occurs. I'm completely stumped. Maybe you should see what the manufacturer of your video input has to say about it? Once again, I'm sorry that I can't be of more help to you... -- MIKE |
| I've obviously not been clear enough here! This has nothing to do with the Nav unit spinning up or down...that all works fine! The only problem that I have is that the the video input unit uses a harness that effectively breaks into the video feed to the screen. My problem is this, to see the Mini logo when I unlock the car, the video unit has to be powered, if it isn't then there is no picture on the screen. If I leave it permanently connected like I have at the moment the battery runs down as the video unit draws too much current....everything else shuts down as it should do. Is that any clearer? All I need is a signal from the car that goes 'high' when the car is unlocked so that I can run it via a relay and not have the current draw on the battery.When I lock the car again the signal needs to go low and therefore de-energize the relay and cut power to the video unit. Any more ideas? Cheers, Tom... |
| dogzdinner, please tell us which aftermarket video input unit you are using. I expect to purchase an OEM or aftermarket unit soon, and want to be aware of any issues I may encounter. |
| The aftermarket ones are all pretty much the same....I think mine was from www.navwithtv.com but I'm not 100% certain...it just give you the ability to switch between the Nav Screen and the chosen composite video input. The important bit is that it came with the appropriate BMW NAV connectors. Cheers, Tom... |
| FAO: Mikey or anyone else who can help! | Gavin1980 | First Generation Interior & Ice | 6 | May 28th, 2007 09:59 PM |
| Not long for MIKEY now.. | :: Jon :: | General Discussion | 27 | Aug 17th, 2006 06:54 AM |
| Mikey - MFSW Question Pioneer DEH-P7800MP | Joe Kewl | First Generation Interior & Ice | 0 | Aug 4th, 2006 05:32 AM |
| New Mikey project on the way | mikeythemini | First Generation MINI Exterior | 18 | Mar 5th, 2006 11:31 AM |
| Yet another Mikey Question.... | DaFlake | First Generation Interior & Ice | 2 | Nov 26th, 2005 05:01 PM |
