Top sensors (not boot switches) - MINI Cooper Forum
First Generation MINI Convertible MINI Convertible (MINI Cabrio) 2004 - 2008
post #1 of 4 (permalink) Old Jun 19th, 2014, 03:32 PM Thread Starter
Local Time: 08:10 PM
I have an 05 mini, lately it's been acting up. Occasionally it stops going down past the sunroof stage. It unmatched and then nothing. When latching it you have to hold the button a bit and it makes a noise then latches and then you can close the sunroof.
Now I've already taken an ohm meter to all of the switches in the trunk and everything checks out. I've checked the front buttons as well, all is fine. Now I did an experiment after stalking around some more. I left it in the su. Went outside at 10 am and it didn't work, again at 11. The. I parked her under a tree and 2 hrs later went down no problem. Then later that night once again down with no problem.
now the reason I tried that is cause I was reading about a sensor that tells the motor to shut off to prevent overheating. Is it possible this sensor has become too sensitive? If so where is it? Or is it more likely that somethings catastrophically wrong with the motor and it is overheating (which doesn't seem likely to me, never hirts to get opinions though)? Which once again not sure where they are, I have the general idea they're near the rear seats but how do you get to them comfortably? Also is there anything else like another sensor that could be causing this?
Thanks in advance for any advice and opinions on the matter. I really dislike dealerships
jagojay is offline
post #2 of 4 (permalink) Old Mar 22nd, 2016, 10:42 AM
Hi
Did you solve this problem?
I have the same problem with my 2004 R52. It will not open more than the sun-roof. The buttons in the trunk are working fine, and the
mobilolsen is offline
post #3 of 4 (permalink) Old Mar 22nd, 2016, 10:43 AM
Hi
I have the same problem with my 2004 R52. It will not open more than the sun-roof. The buttons in the trunk are working fine. Are there any top sensors that need to be checked? Where are they located?
-john
post #4 of 4 (permalink) Old Mar 22nd, 2016, 10:50 AM
Moderator
minione2002's Avatar
Quoted: 418 Post(s)
Originally Posted by mobilolsen View Post
Hi
-john
Try creating your own thread
minione2002 is offline
09 cooper convertible boot lid problems Aysh Second Generation MINI Convertible 4 Dec 3rd, 2012 08:59 PM
