Glove box issue - MINI Cooper Forum
First Generation MINI Convertible MINI Convertible (MINI Cabrio) 2004 - 2008
post #1 of 4 (permalink) Old Jul 9th, 2014, 01:11 PM Thread Starter
Local Time: 09:09 AM
Glove box issue
I just bought a 2007 Cooper S R52. Unfortunately the glove box refuses to open. The handle is in place but the center of it is missing (round opening in center of chrome lever). Is there any way I can open this without a crowbar.
I presume the lock cylinder is missing which disconnects the handle from the mechanism. Any suggestions?
Many thanks
barose is offline
post #2 of 4 (permalink) Old Jul 13th, 2014, 10:29 PM
Local Time: 08:09 AM
Many thanks
I just got my s convertible and the glove box wouldn't open. I found I could get my fingernail up inside and hook the latch or I could use a paper clip shaped like a hook to grab the latch to get it open. (If you're small enough, you can lie on your back and look up into the void to see it.)
After I got it open, I fed a cable tie around the latch and cut it off to where I could grab it, but not see it. Opens easily.
doxbike is offline
post #3 of 4 (permalink) Old Jul 14th, 2014, 11:54 AM Thread Starter
Thanks for that Doxbike!
Sounds like you have the same glove box. I have tried pushing and pulling with a bent coat hanger, (half inch 90degree bend) for several sessions, total of a couple of hours. I cannot see what to hook onto. Mostly have been using a small mirror to look up as lying down and looking up does not seem to work for me. Any further help in what to pull would be extremely helpful.
barose is offline
post #4 of 4 (permalink) Old Jul 14th, 2014, 01:36 PM
You're trying to get hold of the seahorse shaped plastic latch and pull it down/forward. Mine had the piece broken off that attaches the latch to the chrome piece.
Stick your middle finger up into the hole, curl it back toward yourself (like you were trying to pick your nose, sorry, and see if you can hook the latch where the piece was broken off.
Name:	glove box latch.jpg
doxbike is offline
Glove box hi guys Kelscooper First Generation Interior & Ice 6 Apr 3rd, 2014 09:40 PM
How to remove lock cylinder from glove box? need4speed General Discussion 0 Mar 24th, 2013 05:41 PM
Mini 04 Cooper Converitable R52 Glove Box Locking Latch intel First Generation Faults & Fixes 0 Feb 24th, 2013 09:21 PM
Glove box rattle squeak (fixed) James burbidge First Generation Faults & Fixes 2 Aug 30th, 2012 04:57 PM
Passenger side Lever/switch under Glove Box? kerosenetrewthe General Discussion 2 Aug 9th, 2012 03:44 PM
