Wind Deflector - Help! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Convertible > First Generation MINI Convertible
First Generation MINI Convertible MINI Convertible (MINI Cabrio) 2004 - 2008
Old Jul 7th, 2004, 03:54 PM
Local Time: 05:37 PM
Question Wind Deflector - Help!
Does anyone have ANY idea how to fold the wind deflector back down?!! I've never been any good at those Rubicks (spelling?) Cube things!!
Old Jul 7th, 2004, 04:01 PM
hunkey dorey's Avatar
'MINI' or 'MAXI'??!
England
it's easier if u have someone to help u remove it... one person stand at either side of the car.
From memory, you just slide the clips at each side (at same time) and pull it out.... don't need to force it tho!.... then the fun begins.... trying to fold it to put it back in its bag!!!.... but i got illustrative instructions with mine that are easy to follow... did u not? or are u one of these people who doesn't follow instructions and would prefer to struggle on ur own? (oh no sorry... that's men that do that isn't it!!! .... sorry couldn't resist that!! ... Apologies to the men!!)
((PS> if u just want to 'fold it down' and not actually remove it... you just 'push it down'!!))
Old Jul 7th, 2004, 04:28 PM
EV Mini
Local Time: 04:37 PM
Once removed from the car, you fold the deflector up by getting the upright section flat first. If you look at the two ends where the upright bit hinges, one will have a screw in the end and one won't The end without the screw can be released by pulling back the outer plastic trim which will pull back the pin holding the upper screen in the hinge. Once the upper section is flattened to the horizontal screen then both sections can be folded in half so you fit it back into the holding pack
Wind deflector cejsmith First Generation MINI Convertible 23 Mar 21st, 2005 11:42 PM
Wind deflector HDgaz First Generation MINI Convertible 6 Mar 12th, 2005 01:03 PM
Wind Deflector... ardohead First Generation MINI Convertible 3 Jun 7th, 2004 08:39 PM
