| First Generation MINI Convertible MINI Convertible (MINI Cabrio) 2004 - 2008 |
| View Poll Results: Has your convertible got a worn roof? | |||
| I have a NEW roof and it shows no wear | | 6 | 9.52% |
| I have a NEW roof and it is marking already | | 23 | 36.51% |
| I have an old roof and it is not marked | | 0 | 0% |
| I have an old roof which is very slightly marked | | 14 | 22.22% |
| I have an old roof that has a few worn patches | | 9 | 14.29% |
| I have an old roof that is badly marked | | 4 | 6.35% |
| My roof is so bad it is embarressing to park it | | 2 | 3.17% |
| I have had or am waiting for a replacement roof | | 5 | 7.94% |
| Voters: 63. You may not vote on this poll | |||
I got my MCSC in February and by end of April i had to get new hood and mechanism because of wear, this NEW hood has only been on a month i already have wear starting in exactly the same places. |
My Bran new roof Hi, I managed to get my roof changed by Mini. It was changed last wednesday or so, and when i turned up it was lovely and blue. I picked the car up on Friday and since then the roof has been up and down about 12 times (the weather in britain isn't predictable!) and in that week there are already the white marks, and the rubber line that follows the back windows has started to deform!! It is pretty obvious too!!! I'll try and get some pics and put them up but this just shows how bad the situation is!! Also while my car was in 2 new rattles, 1 hole in gear stick gator, and they still haven't stopped it from drifting to the left....but they have found out it needs a new gearbox!!!!!!! luckly its a warrenty thing again some noise (one i've never noticed...but its getting changed anyway!!) |
| I have a March '05 build with a black top and I do have marks in all the known spots. I think I have a newer modified top. Although the marks are not as white and prominent as others - you can still see the wear areas. My dealer calls it "normal wear". I'm wating for a U.S. fix then calling MiniUSA. My dealer is no help. |
| going for 3rd roof had roof changed, white spots appeared within 3 days, reported to garage who in turn reported to MINI/BMW who replied with a query for dealer to ask customer to return (again) to see if roof number 2 was an original or a modified one, they don't know which was supplied (!) The way to confirm this is to measure the distance from the bottom of the hood, by the boot, to where the stitching goes into a fold, old roof being 15mm new roof being 40mm. Guess which one they fitted to mine I will say at this point that my dealer has been very helpful and sympathetic. I did make the suggestion that on the PDI of all new convertibles the roof be fully opened and a piece of A4 paper slid between the canvas, if it slides without resistance then I would suggest that the new owner will not get the dreaded 'white spot' (I thought that was a disease that tropical fish got !) and if it doesn't then adjust the dam thing and everyone is happy including MINI as hey will no longer have to shell out for new roofs. Just a thought. |
| I'm on my 2nd new roof, wear already started, I think your measurements may be round the wrong way, the old roof is 40mm from the boot to the stitching and the new one is only 15mm. Anyhow keep complaining, like all manufacturers they will only react if you complain, if you have roof wear and don't complain they will not rectify it! |
| Although I've sold mine now, it did have the wear marks on the Blue hood within weeks of getting it. When I complained to BMW they tried to fob me off with "it wasn't bad enough yet". By mistake a junior in the dealer printed off the document relating to problem. Ref for others is 54 34 90 69 00. Underneath Remendy it has listed " The following measures are only to be carried out in the event of a customer complaint if pressure & chafe marks are apparent in certain areas". It then refers to diagram showing 3 areas that most of us had experienced. It was only when I got the Manager out & showed him I had the printout & threatened using a solicitor that he backed down & agreed to replace. Lesson for others , do not give in & ask for doc ref above with title " Chafing and pressure marks on convertible top cover". Good luck |
| Is this wierd? I was suffering the same white marks as everyone, until I used 303 Aerospace on the fabric. That was about 2 months ago, and the white marks have gone...I haven't been to the dealer or anything, and have had the roof up and down lots as the wether has improved. Coincidence or what? Not here much any more |
I've got the same problem with wear on my roof and my dealer took photos which were passed to the regional technical manager. Coincidentally there was another custoner in at the same time complaining about his roof. They've said that apparently Mini UK aren't aware of the problem. When I cited all the cases from this site they laughed it off as Internet nonsense. Has anyone else been given this line of fob off? My dealer has said that they've posted the problem on their "PUMA" site, which is MINI UK's internal network, to see if it comes back as a known issue and to see if there's a modification in the pipeline. |
Load of Rubbish! Some dealers This is similar to what my dealer said, but a bit worse! My dealer has refused to changed my hood again (2nd time) untill the BMW technical specialist see's it. Basically the 2004 hood was revised and replacement hoods are now the newer 'BMW fixed' hood....But as mine started to wear again within a week its obviously not well engineered. What I did was make sure the dealer told me my hood needed replacing, and he did! But like i said to him I find it highly inconvenient to keep leaving my car with them, while I drive a ONEd (no disrespect intended)....and he thought it would be a waste of time replacing it for exactly the same model hood. The BMW techy has the chanllenge of overcoming this hood problem, without ruining the lines/style of the car...not an easy task, but one that they should have done before releasing it in 2004. This BMW Techy ordered MINI to replace my gearbox, and I had never complained once!! So it can't all be bad news!!! *Mine goes in early July...I'll keep you posted with any information! BEST OF LUCK TO US ALL!!!! |
| I noted that there was a letter in this months GoMINI about roof wear, and that there was no problem ![]() shows they haven't a clue about the car they write about ![]() My new roof, is slightly marked, but no where near as bad as the original, but since the new one, its gained rattles and squeeks |
| Any Current Roof Problems on Recent Model Convertibles? | AidenL | First Generation MINI Convertible | 15 | May 27th, 2007 06:13 AM |
| New after market solution to roof wear in convertibles | simeds | General Discussion | 4 | Sep 25th, 2006 11:01 AM |
| Forget Roof Wear... | MadisonMini | First Generation MINI Convertible | 98 | Jun 8th, 2006 11:43 PM |
| roof wear and Towson | ErikR | First Generation MINI Convertible | 1 | Feb 28th, 2006 04:53 PM |
| Roof wear problem | minicabrio | First Generation MINI Convertible | 278 | Sep 2nd, 2005 08:47 PM |
