Jacking up the Mini - MINI Cooper Forum
post #1 of 26 (permalink) Old Aug 12th, 2002, 03:36 PM Thread Starter
Local Time: 09:12 AM
Jacking up the Mini
Where's the best place to jack the Mini S up, front & rear? Where's the best place for the stands? I've got the stands in the picture which have a rubber pad in case I have to support the car on the frame rails (like I used to do on my old BMW 2002). SD
Ultgar is offline
post #2 of 26 (permalink) Old Aug 12th, 2002, 07:18 PM
OhioCowboy's Avatar
Local Time: 04:12 AM
This is where I put the jack. I was able to lift both wheels off the ground at the same time lifting at the front lift pad to rotate the tires.
Cooper S EB/W/Mag
OhioCowboy is offline
post #3 of 26 (permalink) Old Aug 12th, 2002, 08:32 PM
M7SPEED SPONSORED MINI !
minime s's Avatar
Local Time: 05:12 AM
That's were I lifted mine from.........no problems.....
1/4 mile 13.07 @109mph...258 wheel horsepower,
03 cooper"S" Pure Silver,18" Kahn's,Aero Kit,Nitrous Express NOS kit(50 shot),Evotech Computer upgrade,ALTA intake,short shifter,Magnaflow exhaust,header,pulley upgrade,cam,H&R springs,quaife,MSD Coil a
minime s is offline
post #4 of 26 (permalink) Old Aug 13th, 2002, 10:54 AM
Silvercooper's Avatar
Canada Male
While you're talking about it, I believe MINI doesn't recommend to rotate the tire. I found it a bit weird but that's what I read in the Mini owner's book, they say it could in fact reduce the efficiency of the tire because of the way the aligment is on the car, each tire should wear differently. I'm curious to hear what people on this forum think about that?
Silvercooper is offline
post #5 of 26 (permalink) Old Aug 13th, 2002, 01:51 PM
oldcrow's Avatar
United States View oldcrow's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
whose yellow mcs is that... mine was loaded on the Falstaff a few days ago.... could you post a few pics.. to feed my eyes while I continue to wait
LY/BLK MCS, Prem, Sport, Roof Rack
oldcrow is offline
post #6 of 26 (permalink) Old Aug 13th, 2002, 02:12 PM Thread Starter
The Mini's new home is being built...masonite sheets are down to protect the finished floor while the contractors make their mess. I should be able to work on the car without a floor jack when the shop is done and can stack cars in the garage during the winter. SD
Ultgar is offline
post #7 of 26 (permalink) Old Aug 13th, 2002, 02:34 PM
smiffy's Avatar
Wales View smiffy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Send a message via MSN to smiffy
I want a garage like that
S for Smiffy
"Kids in the front seat cause accidents, accidents in the backseat cause kids!"
smiffy is offline
post #8 of 26 (permalink) Old Aug 13th, 2002, 02:52 PM Thread Starter
Here's another Yellow S
Ultgar is offline
post #9 of 26 (permalink) Old Aug 13th, 2002, 05:55 PM
OhioCowboy's Avatar
Question
I must have missed the 6 cylinder option package when I ordered my MCS!
Cooper S EB/W/Mag
post #10 of 26 (permalink) Old Sep 11th, 2002, 12:12 PM
So rotating the tires is recommended? Do you have recommendations on when and how?
gjenkins is offline
post #11 of 26 (permalink) Old Sep 11th, 2002, 05:33 PM
noahe's Avatar
Canada View noahe's Chili Red & White 1st Gen MINI Cooper S Profile
Garage
All I could find is this on page 84 of the manual:
Tire changes between axles
Depending on individual operating conditions,
different wear patterns appear on
the front and rear axles. In the interests of
safety and optimized handling characteristics,
a change between the axles is not
recommended.
But that is very vague. What do they mean by 'changes between axles'? As in mixing types, brands or condition tires? Does this indeed refer to a rotation, or swap of tires on each axle?
Chilli Red/White Cooper S, Sport Pack & Sunroof. Delivered June 12th, 2002!
Now with MCS Winter Tire Package.
noahe is offline
post #12 of 26 (permalink) Old Sep 12th, 2002, 12:29 PM
Canada Male
That's exactly what I wonder, a lot of guys on this Forum are talking about rotating their tires so I don't know if it's because they didn't read their owner's manual or they just ignored it. I will definitely ask my dealer next time I pass by.
post #13 of 26 (permalink) Old Feb 2nd, 2004, 02:04 PM
Total MINI dot com!!
Rakey's Avatar
Local Time: 10:12 AM
United Kingdom Male View Rakey's Classified Ads
Ok this is the closest thread I have found to what I need to know, I have been reliable informed that I can rotate the wheels from corner to corner, but now this is going to sound daft, anyone got any tips to get the wheels off the car without damaging them. As they feel like that have completely bonded to the car?
Help??
Rakey is offline
post #14 of 26 (permalink) Old Feb 2nd, 2004, 02:32 PM
work, work, work...
United States View agiduda's Dark Silver & Black 1st Gen MINI Cooper S Profile
Loosen lugs to finger tight and drive for a hundred feet or so with a couple hard stops and a toss of the steering back and forth. Then you should be able to get them off.
If you do this without lugs please post pictures.
agiduda is offline
post #15 of 26 (permalink) Old Feb 2nd, 2004, 02:32 PM
AWOL
northandy's Avatar
England View northandy's Electric Blue & White 1st Gen MINI Cooper S Profile View northandy's Classified Ads
Help??
I had this trouble mate.... only 3 weeks ago !
managed to get three of them off by battering the tyre from the inside with a rubber mallet... altho its not very safe.... for one of them i undid the bolts so they were just finger tight... the drove it down the drive... that broke the bond.... it be careful not to brake hard mind you... its quite unnerving when it gives.... them just clean up the spigot with fine emery cloth and a bit of copper grease should stop it happening again !
northandy is offline
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 05:36 AM
Brands Hatch Mini Festival 22/23 June 2013 mab01uk Mini Events 20 Jun 23rd, 2013 10:03 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 06:11 PM
Mini jacking points Nicko999 Maintenance & MINI Care 4 Oct 24th, 2012 08:54 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 05:29 AM
