| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| Don't turn that screw, it could break. Just abrase the screw end until the valve is closing so it leaves the smallest gap possible. Don't abrase too much of, you can't put it on again ![]() In case you ever wonder where your power has gone when that happens, 50% chance this bypass valve is broken. I had to fit a new one because the spring that helps closing the valve was broken. It may give you a little bit more pressure if your valve was badly adjusted in the plant. EB/W R53 MCS Highly Modified |
| It saves you lots of fuel ![]() It gives less pressure when you don't push the gaspedal so you don't drive around with full kompressor pressure all the time (and thus saves fuel). Opening the throtlle body closes the kompressor bypass valve giving you the full benefit of the kompressor. EB/W R53 MCS Highly Modified |
| Optimise Bypass Valve | MuffinMan | First Generation MINI Tuning | 1 | Nov 22nd, 2006 06:01 PM |
| Bypass valve removal | Scoobystu | First Generation MINI Tuning | 9 | May 25th, 2006 12:56 PM |
| Bypass valve recalibration | THE ITCH | First Generation MINI Tuning | 33 | Feb 16th, 2006 08:58 PM |
| GTT 210 'optimised bypass valve' | venox22 | First Generation MINI Tuning | 6 | Aug 24th, 2005 05:29 PM |
| Eaton bypass valve | FAT MINI | First Generation MINI Tuning | 4 | Oct 4th, 2004 01:01 PM |
