Roundabout understeer? - Page 2 - MINI Cooper Forum
post #16 of 28 (permalink) Old May 3rd, 2007, 11:48 AM
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Local Time: 11:53 PM
Originally Posted by Japper View Post
Never found that. When you do induce a bit of oversteer it is easily corrected with throttle and a bit of oposite lock......never had a tank slapper.
Maybe i cut my teeth on pug 205gti's and clio 16v's.....now they bit big style
Yep Pug 205's and Nova SRi's are reknowned for biting boy racers.
It was acceptable in the 80's
Root Ginger is offline
post #17 of 28 (permalink) Old May 3rd, 2007, 11:54 AM
Local Time: 12:53 AM
United Kingdom Male View grantw's Solid Black & Body Color 1st Gen MINI Cooper S Profile
of all the cars that I have driven, I find the mini brilliantly balanced, its adjustability is fantastic.. you must be overdriving the car if your having problems with 'scary' oversteer in a mini..
grantw is offline
post #18 of 28 (permalink) Old May 12th, 2007, 06:31 PM
MCS
Local Time: 02:53 AM
Cyprus Male
Send a message via MSN to steven888
omg...u say (Its awful in my MCS and its one of the only things that lets the car down). MCS is one of the Best Handling cars...and thats what it does the BEST!! If there is a problem with your tires or your driving dont blame the car. Sry for saying this but Minis had and have great handling and should be treated with Respect.
MINI COOPER S POWWWERR
A car like no other......
steven888 is offline
post #19 of 28 (permalink) Old May 12th, 2007, 06:47 PM
The Estate Agent!!
eggtruck's Avatar
United Kingdom Male View eggtruck's Astro Black & Body Color 2nd Gen MINI Cooper S Clubman Profile
I only get understeer in the wet.
eggtruck is offline
post #20 of 28 (permalink) Old May 13th, 2007, 08:49 PM
Blackpool Rock
Westy's Avatar
England Male
Production cars are designed to understeer rather than oversteer when you turn, in for supposed safety reasons, that's just how it is, what else are you expecting to happen once it starts breaking away?
Are you bothered by the fact that it is starting to slide (in which case drive slower) or is it that you want it to break away neutral or into oversteer? - If you want a neutral handling car you are going to have to set it up accordingly.
My Westfield in the avatar is actually a slightly understeering car on an even throttle but has been pushed into oversteer on throttle (in the pic). It would do the same as your Mini, just at higher speeds.
Westy is offline
post #21 of 28 (permalink) Old May 17th, 2007, 11:32 AM
mini50man
Frank.B's Avatar
Local Time: 10:53 AM
Australia Male
Australia Is the problem behind you?
I fitted a 22mm diameter 3 position adjustable rear sway bar replacing the standard 18mm (Cooper) rear bar - (19mm on the MCS). The back of the car stays flatter now and tends to follow the front rather than push it on. It also works well under heavy braking from high speed on track days.
Check the Mini Mania Web site. If you only change one thing it should be the rear bar. It involves lowering the rear sub frame so allow half a day to fit it!
Frank.B is offline
post #22 of 28 (permalink) Old May 17th, 2007, 08:36 PM
It's interesting what you say about braking. Does this mean the bar eliminated that jitteryness from the rear that I feel under heavy braking?
post #23 of 28 (permalink) Old Jun 5th, 2007, 11:00 PM
Rattie
DevilRat's Avatar
United Kingdom Female
Blue Cooper
Originally Posted by Root Ginger View Post
Forgot to mention driving technique as well. Slow in, fast out.
Most people make the mistake of braking too late, carrying too much speed into the bend and ending up understeering and not being able to get the throttle down. Get your speed down earlier and enough not to understeer, cruise through the bend and you'll find you can get on the throttle a lot sooner.
It's smoother and it's quicker.
Good advice
Sounds like someones done a track day!
DevilRat is offline
post #24 of 28 (permalink) Old Jun 15th, 2007, 09:33 AM
Originally Posted by DevilRat View Post
Good advice
Just a couple
It amazing how much faster you can go just by calming down a bit and making everything nice and smooth.
post #25 of 28 (permalink) Old Jun 15th, 2007, 04:26 PM
Rattie
DevilRat's Avatar
Blue Cooper
Just a couple
I did a single seater experience at Silverstone & learnt my lesson about how fast to enter a corner. I overtook 2 cars on a straight then ended going into a corner too fast so the car spun right round!
DevilRat is offline
post #26 of 28 (permalink) Old Jun 15th, 2007, 04:35 PM
258.3bhp and 263.1Nm
MiniPetrolHead's Avatar
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile View MiniPetrolHead's Classified Ads
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
Originally Posted by grantw View Post
I find the best way to tackle a deserted roundabout is to be fast in, but inducing a little lift off oversteer by quickly letting off the power on turn in, even with standard runflats this helps balance what would be impending understeer.... though be ready for the back end to come into play..
Fantastic fun doing this but the other night i did freek myself out abit doing it when the back end comes out abit to far and you have to try and correct it!
I think i just need some more practice!
Alex
MiniPetrolHead is offline
post #27 of 28 (permalink) Old Jun 16th, 2007, 12:19 AM
Minitastic
minimike7's Avatar
United Kingdom Male View minimike7's Classified Ads
Send a message via MSN to minimike7
was the the formula ford day single seaters?
I did that for my 21st, was amazing, never span it, I had some good lap times as i was slow in and fast out the bends unlike some of the nutters who span it lots as they belted past on the streights but didnt break for the corners.
I did the italian job day up in Loughbourogh too, that was very good, e type jag was great fun, no power assited anything in that best
minimike7 is offline
post #28 of 28 (permalink) Old Jun 16th, 2007, 12:10 PM
Rattie
DevilRat's Avatar
Blue Cooper
It was formula fords at the Stowe Circuit at Silverstone. After I had been out for a few laps my instructor told me "I know your dad, & he says go faster," so I did & that's when I span off! But I only span off once & I didn't stall it!
Name:	Silverstone Formula Ford.jpg
DevilRat is offline
