| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| Think I've answered one question. No they won't fit without spacers. I printed off the template (AP) and I think it'll require at least a 20mm spacer My mini is also lowered 30mm on KW springs. I'm not sure it would handle a 20mm spacer as the fronts already look incredibly close to the bodywork. Anyone else had my problem?? Cooper S Hyper Blue - GTT/GRS/Speedline/KW |
| If you go to our website and select a big brake kit ,there is a tech info button,select it and you can download a template ,print off and cut out , then you can put template inside your wheel and check for clearance,AP,BREMBO,AND WILWOOD available, spacers 5mm to 40mm available and stud conversion,or longer wheel bolts. |
| Thanks Minimania, I've swayed towards the Wilwood kit now as they hopefully will fit, even if it does require a smaller spacer. Do the lines come with the kit? the website say you need to order seperate but the product code shows nothing up? Cooper S Hyper Blue - GTT/GRS/Speedline/KW |
| Tags: brakes, r90, wilwood |
| What Big Brake Kit ??? | beatbox | Wheels, Tyres & Brakes | 27 | Jan 14th, 2008 05:39 PM |
| Big brake kit | SMG | Wheels, Tyres & Brakes | 41 | Feb 12th, 2007 08:01 PM |
| Big brake kit | suprchrgdmini | First Generation MINI Tuning | 7 | May 20th, 2003 09:08 AM |
