Basic Question Time: Why does the supercharger whine? - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Dec 17th, 2007, 03:38 PM
Tigger, Eeyore & Roo's Avatar
Focus RS & Land Rover FL2
Local Time: 03:26 PM
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile View Tigger, Eeyore & Roo's Classified Ads
Read that.
Interesting though, because the article describes the twin screw and centrifugal supercharger as whining, but not the Roots (which, I believe, is the one that the MCS uses)
And, if it isn't anything to do with straight cut gears, why does it seem to be most related to engine load, rather than engine speed?
It seems to have been blown wide open again...
Tigger.
May '04 - Feb '07 R50, Feb '07 - May '10 R53. Enjoyed our time with MINI's, but ran out of space! Now Focus RS & Land Rover powered...
  #17 (permalink)
Old Dec 17th, 2007, 07:29 PM
MINI-Bob's Avatar
I want that one!
Local Time: 02:26 PM
United Kingdom Male View MINI-Bob's Classified Ads
Interesting read that.
Think until someone has a definitive answer to what type of s/c the MINI uses, we're a bit stuck.
  #18 (permalink)
Old Dec 17th, 2007, 08:39 PM
It's definitely not the centrifuge type. I've heard it referred to as a Roots type, but when I say one it looked like something half way between the Roots and the twin screw type
  #19 (permalink)
Old Dec 17th, 2007, 08:52 PM
r1_kde's Avatar
JCW 210 apparently not!
United Kingdom View r1_kde's Classified Ads
Its 100% a roots blower. The reason it gets louder under load is "A" your opening the throttle and letting more air in which creates compression of air, hence this makes the rotors hot and they mesh more. "B" The sound carries back through the throttle and air filter which almost amplifies the sound. When you change to a cold cone intake the sound is louder, its down to the design of the cone and the sound insulating properties.
I own a celica 1zzfe which I have custom built an M45 blower on. Attached is the celica running NA with the blower turning, this is what your blower would sound like if it was only turning and not connected to your engine. This was fecking loud.
P1000045.flv - Video - Photobucket - Video and Image Hosting
Also just to show the engine as almost complete.
Just turning the blower over with your hand creates a whine as the lobes mesh! then when the expand they become louder and louder. Also worth nothing that the sound will find a way out. Hope this helps
  #20 (permalink)
Old Dec 17th, 2007, 09:23 PM
Great, love the video Just like the MCS, but much louder!
Tigger.
  #21 (permalink)
Old Oct 24th, 2008, 11:32 PM
Local Time: 10:26 AM
I'm new to minis, I just bought a cooper works, and I'm curious why the engine makes whine after I shut down the car
  #22 (permalink)
Old Oct 25th, 2008, 07:25 AM
T o t a l m i n i . c o m
I Believe that the Cooper S uses a "positive displacement supercharger" rather than a "Cencentrifugal-type supercharger"
and I was told that the whine is the air particles hitting the impeller inside the Supercharger housing, and this creates the amazing whining sound
Please correct me if I am wrong
  #23 (permalink)
Old Nov 1st, 2008, 11:23 AM
hollinshead's Avatar
United Kingdom Male View hollinshead's Hyper Blue & Black 1st Gen MINI Cooper S Profile
Quote: Originally Posted by r1_kde (original)
The superchargers whine because of the rotors meshing, as the tolerances are so close to ensure there is air pressure held, the rotors make a whine towards higer spreeds. Should you ever have the blower out of the car and turn by hand you will hear the sound of the rotors meshing. produces a sound like gears but it is the rotors just about touching, pre face lift should be louder at high speeds due to the lack of teflon coating.
Howstuffworks "Supercharger Basics"
Read the page, it helps with the basics.
Does this mean the only difference between the SC fitted to the facelift R53 and the Works one, is the size of the pulley?
  #24 (permalink)
Old Aug 1st, 2011, 03:54 AM
Tonga
only whines under load?
the answer is in the question.
load.
larger throttle opening
exposes more air to the rotors
more work= more noise
  #25 (permalink)
Old Aug 1st, 2011, 04:55 PM
Hey, I asked that question over 3 1/2 years ago!
One thing I did learn later on is that the air box really muffles the noise the rotor blades make! A decent induction kit not only improves the performance, but really lets you hear the supercharger working
Tags: ,
Supercharge oil Fengtau First Generation Faults & Fixes 0 Nov 21st, 2005 02:04 PM
supercharge , a non supercharge cooper (2002) maninblack First Generation MINI Tuning 1 Sep 12th, 2004 02:33 PM
supercharge maninblack First Generation MINI Tuning 4 Apr 6th, 2004 02:54 AM
Embarrasingly basic question! stuartkey First Generation Interior & Ice 4 Jun 13th, 2003 07:01 AM
To Supercharge or Not to Supercharge that, my friends, is the Question!! Adventure_Man First Generation MINI Tuning 19 Mar 26th, 2003 03:11 AM
