deteriation in exhaust emission values- help! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 17th, 2008, 06:08 PM
mini world's Avatar
Local Time: 03:27 PM
Smile deteriation in exhaust emission values- help!
Hi everyone,
I own a 02 reg dark silver MCS- had it about six months- (I LOVE IT)
Today- a warning light came on the dashboard- I looked in the book and it says its "engine- deteriation in exhaust emission values". The car sounds a bit nosier now too.
I have some questions:
Is it normal to have this problem- the car has done 27,000 miles
Do you think I need a new exhaust?
How much will this cost? My mate had a quick look and he said I may need a middle section and a rear section....
Can I get it fixed at somewhere like Kwik fit and not BMW for the cheapest deal? Will they be able to re set the warning light in non BMW garages?
Please excuse my ignorance! any help much appreciated- thanks....
Mini world
Old Feb 17th, 2008, 09:30 PM
MINI-Morgan's Avatar
MINI Obsessed...
Middle and rear? Hmmm well since the sensors are all part of the manifold it would have to be the CAT thats failing in most cases. I'd get the fault codes read before you worry too much as the light means there is a fault that can effect emissions but might not be the exhaust.
Old Feb 18th, 2008, 04:37 PM
MarkW's Avatar
XR3i / JCW MCS
could b a sensor failure
Old Feb 18th, 2008, 05:30 PM
sounds like a cat failure -light on and increased noise, also check the exhaust is not split where the cat is fitted
Old Feb 19th, 2008, 09:24 AM
mini world's Avatar
latest news
Hello- thanks for your responses!
The warning light turned off yesterday by itself.
I went to Kwik fit anyway and the guy had a look. He said that the exhaust looked fine- but could be that the CAT is going. He told me to come back when the warning light comes on and he will do a diagnostic test to see what's wrong.
will this be expensive???
should I be driving like a granny from now on???
Old Feb 19th, 2008, 01:00 PM
MINI Obsessed...
Does it go off again when a CAT effiency error is triggered? Id still get someone to read the fault codes.....
Kwik Fit might not be the safest place to take it especially since the triggering code will still be there even though the light has gone out.
Old Feb 19th, 2008, 03:57 PM
mini world's Avatar
hello
Hi MINI- Morgan,
The light hasn't come back for two days, haven't noticed an increase in noise yet...
Fault codes? I guess I would need to take to BMW to get them to read?
Not sure if it is the CAT- the guy said it could be but to carry on driving until the light comes back on.
Old Feb 19th, 2008, 04:12 PM
MINI Obsessed...
Any decent garage should be able to do it. But if you arent worried and it hasnt come back then I cant see the harm in leaving it and see if it comes back and if they pick it up on your next service
Emission light & mot shurm First Generation Faults & Fixes 0 Feb 12th, 2007 07:40 PM
Carbon Emission Offset Rakey General Discussion 12 Aug 30th, 2005 03:00 PM
Emission Test with Milltek Header and Exhaust!!! Faat Canada 1 Feb 8th, 2005 11:53 PM
emission values rasp First Generation Faults & Fixes 3 Oct 25th, 2004 09:53 PM
Help Emission Warning Light On.....? mn_angrybeats First Generation Faults & Fixes 3 Sep 20th, 2003 09:02 AM
