When was LSD made standard? - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Mar 24th, 2008, 06:29 PM
Hugo's Avatar
Nearly there
Local Time: 03:27 PM
Northern Ireland Male View Hugo's Dark Silver & Black 1st Gen MINI Cooper S Profile
Its only when you've got the power on it prevents understeer.
  #17 (permalink)
Old Mar 24th, 2008, 08:01 PM
Local Time: 02:27 PM
United Kingdom View JDM_at_heart's Classified Ads
Quote: Originally Posted by joshie (original)
Does LSD stop you sliding out on corners, or just mean you get more speed out of a corner?
Best way to explain it I think is if you consider a pencil inbetween 2 cotton reels (simple axle with 2 wheels). When you turn a corner, the outside wheel has to travel a further distance to the inside wheel, so if you enter a corner too fast with a regular diff you will understeer and fall away from the corner.... however, with an LSD, it will put more power to the wheel on the outside that has to go the further distance to help anchor you into the corner. I used to have an LSD on my previous FWD car. Unfortunately I never got around to 'tracking' it but I had a play about with the LSD on some 'private grounds' and it's pretty cool to experiance what's actually going on. You can actually feel the nose of the car turn in towards the roundabout/apex of a corner like you would if you were in a RWD car. On fast road driving, even in the wet I found it hard to get the LSD working - then again it could have just been the type of car. Not had my S long enough to see how well it handles without an LSD. Like I said previously though, won't notice much on normal/fast road driving.
As the above poster said, you only get it working with the power on so the diff can put the power to the outside wheel.
Hope it makes sense. :S
  #18 (permalink)
Old Mar 24th, 2008, 10:18 PM
joshie's Avatar
Hypedem
United Kingdom View joshie's Classified Ads
Ahh, so it only works when accelerating around bends!!
Will having DCS instead do a similiar job?
  #19 (permalink)
Old Mar 24th, 2008, 11:07 PM
Loui's Avatar
230whp an counting
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Loui's Classified Ads
Not really in my experience that hinders progress as it apples the brakes
  #20 (permalink)
Old Mar 25th, 2008, 12:57 AM
joshie's Avatar
Hypedem
Ahh, so LSD, doesnt stop you sliding out, or for safety etc.. it just means you can go round corners and pull out of bends more quickly!?
  #21 (permalink)
Old Mar 25th, 2008, 09:46 AM
Loui's Avatar
230whp an counting
LSD has a very wierd feeling to begin with as you may feel like your going straight on then the diff will dig in an pull you round IYGWIM
  #22 (permalink)
Old Mar 25th, 2008, 12:33 PM
It does make you pull out of bends more quickly, but that's only because you're cornering at a greater speed on a tighter line with an LSD working anyway.
If you drove an S with and without an LSD on a road driving quickly, chances are you won't know which 1 has the LSD or not - like I say, with my previous car, I actually had to cain it around a roundabout, round and round and round, going quicker and quicker to actually feel the LSD kick into gear. Maybe it's also an experiance thing. People on the road will slow down before LSD works, especially those who don't fully understand it. Which is of course a good thing!
  #23 (permalink)
Old Apr 2nd, 2008, 11:54 AM
jamiec's Avatar
Scotland View jamiec's Classified Ads
all checkmate's were fitted with one as standard
  #24 (permalink)
Old Jan 5th, 2010, 10:49 AM
Gaffzilla's Avatar
My dealer (that sounds rather dodgy doesn't it?) told me today LSD is no longer available in any shape or form
'07 Mini Cooper S in Sparkling Silver with panoramic sunroof, black Viper stripes and Chili Pack
  #25 (permalink)
Old Jan 14th, 2010, 05:26 PM
In addition to this, an LSD lets you lay down proper no.11's coming out of junctions :-) and also stops the inside wheel on a tight bend spinning up and ****ing all the power away as the power is channelled to the outer wheel instead.
What non standard upgrades have you made to your Mini that you could not live without GAX857W General Discussion 6 Sep 26th, 2007 10:58 AM
Suspension ugrade from One standard to Cooper S standard (SS+) Swiss Sam First Generation MINI One 4 May 11th, 2005 12:49 PM
Lsd maxaroo General Discussion 11 Apr 22nd, 2005 02:04 PM
LSD standard on MCS from Jan 05 build! Magictux First Generation MINI Cooper S 10 Jan 1st, 2005 08:20 AM
Lsd or not lsd ? that is the question ! kezman50 First Generation MINI Cooper S 22 Nov 27th, 2004 01:24 AM
