Servicing early (before the service indicator says so) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 4th, 2009, 11:58 AM
Local Time: 02:31 PM
Scotland View Jazmundo's Classified Ads
I'm wanting to take in my 02 cooper S for its inspection 2 service ahead of when it's "due" (I have 1800 miles to go on service indicator). I would normally wait but the engine has started to make a diesel like sound and I think it would be good to get it serviced now. Does anyone know if I can stick it in early?
Old Jun 4th, 2009, 01:00 PM
DaFlake's Avatar
MMC Member
Local Time: 10:31 AM
Making a diesel sound? If it is clicking, that could be the valves. When was the last time you checked the oil and topped it off?
Most of the time they will not let you take it in early. You could try, but I doubt they will do it.
Old Jun 4th, 2009, 02:06 PM
MINI One Seven
Local Time: 03:31 PM
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
I'm assuming you've got no tlc due to the age. Therefore you can have it serviced when you like! How long was it since the last service?
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Jun 4th, 2009, 02:32 PM
DaFlake's Avatar
MMC Member
Good point... I was thinking TLC.
Even then, I am still curious about the oil question. Some people seem to think that you don't have to check it because MINI services it.
Old Jun 4th, 2009, 03:24 PM
I managed to get mine serviced early. I was getting the brake fluid changed though and it was 1200 miles from its next service. So I spoke nicely to the service department and they had to call mini for approval.
When I was speaking to the service department the woman said that normally they will only service up to 1000 miles of it being due.
Hope this helps, although its maybe not the answer you wanted!
Tags: , , , ,
Servicing using TLC before service indicator countdown shininghero Maintenance & MINI Care 3 Nov 12th, 2007 07:34 PM
newbie question: where is the service indicator and service countdown metre?? oceanstarBug Maintenance & MINI Care 3 Mar 14th, 2005 08:59 PM
TLC Early Servicing brycem Maintenance & MINI Care 8 Dec 28th, 2004 08:00 AM
Servicing costs - first service Sooper Cooper s Australia 45 May 27th, 2004 08:16 AM
early oil change/ ?re-set the service indicator? KAMAKAZI Maintenance & MINI Care 6 Jan 25th, 2003 11:36 AM
