I jsut brought a Airbag Light reset tool from Ebay... - MINI Cooper Forum
post #1 of 28 (permalink) Old Feb 17th, 2010, 03:48 PM Thread Starter
Local Time: 09:20 PM
United Kingdom View barki's Classified Ads
Hi,
I have a 52 plate MCS and about a week ago the Airbag light came on when I moved the passenger seat forward.
Having checked and rechecked the connections under both seats I decided to buy a Warning Light Reset tool on Ebay for £50. It arrived today and I plugged it in, however rather dissapointingly it has not worked.
How can I tell if this is a problem with the car or a problem with the tool? There appears to be nothing wrong with the under seat connectors yet the light will not extinguish.
I read on here that people have spent £££ with BMW trying to fix the same problem, hence I brought the tool myself.
Tom
barki is offline
post #2 of 28 (permalink) Old Feb 17th, 2010, 06:10 PM
redlinepete's Avatar
Wales Male View redlinepete's Classified Ads
Disconnect the battery then reconnect it...........
redlinepete is offline
post #3 of 28 (permalink) Old Feb 17th, 2010, 06:52 PM
mab01uk's Avatar
Local Time: 08:20 PM
Quoted: 1 Post(s)
I don't think disconnecting the battery makes any difference on the MINI once a SRS fault has been logged in memory.
What airbag reset tool have you bought?
Assumming the tool is suitable for the MINI most will give you a fault code reading which can be decoded to give the faulty component. eg. Left seat airbag firing system, right seatbelt pre-tensioner, etc.
If the fault was only temporary or intermittent, like a bad connection the reset tool should extingush the light, at least for a while. The B200 tool often needs 2 or 3 attempts I have found, and you need to switch on the ignition/start the engine for the SRS system to self check and put out the light afterwards. If this does not work then the fault is likely to be a permanent component failure which may involve replacing something like a seat belt pre-tensioner (cheaper secondhand) or re-soldering some seat wiring connections.
mab01uk is offline
post #4 of 28 (permalink) Old Feb 17th, 2010, 06:52 PM Thread Starter
Hi Pete
I tried that before I even ordered the tool - It turns out that Mini's remember the fault untill it is specifically reset.
barki is offline
post #5 of 28 (permalink) Old Feb 17th, 2010, 07:36 PM Thread Starter
Mab - Thanks for your help
I brought this tool;
Mini BMW Mercedes Airbag SRS Service Reset Tool E36 E46 on eBay (end time 10-Mar-10 18:58:01 GMT)
Do you have any advice on narrowing it down - Im happy to solder etc but would rather get help than waste the weekend figuring it out myself hehe
Thanks again
barki is offline
post #6 of 28 (permalink) Old Feb 18th, 2010, 05:28 AM
Dave Elliott's Avatar
Local Time: 04:20 AM
Quoted: 1 Post(s)
Australia Male View Dave Elliott's Electric Blue & White 1st Gen MINI Cooper S Profile
Thanks again
Hi there,
I use a tool from the same manufacturer and have had no problems. There is sometimes a knack to reading the code in the first place...just follow the instructions given with the unit.
Are you able to read the fault code? If so it should tell you what component is or was at fault. That should help you narrow down the cause. There should be a table of fault codes against description of fault in the instruction book.
Cheers,
Dave
Dave Elliott is offline
post #7 of 28 (permalink) Old Feb 18th, 2010, 09:21 AM Thread Starter
Hi Dave
Thanks for your help - Unfortunately, no the reader that I brought does not display the fault code it simple says 'Reset OK!'.
It does not include a code reading function - Perhaps I should have opted for a better reader.
Im fairly confident that the connector under the seat is at fault, since the light came on when I moved the seat forward - There are two connectors, one yellow and one blue, both with two wires - shall I solder all 4?
Tom
barki is offline
post #8 of 28 (permalink) Old Feb 18th, 2010, 01:04 PM
mab01uk's Avatar
Quoted: 1 Post(s)
No harm in soldering all 4, or just do say the yellow first and then try your reset tool, then blue if no result. If I remember right the yellow is for seat airbag and blue is for the seat belt pre-tensioner unit/buckle. Do not switch on the ignition while wires are disconnected as this will register more fault codes, ideally disconnect battery to prevent any static charge firing an airbag while you are working and it is recommended you wait 15-20 minutes after switching off/disconnecting battery before working on SRS system as some electric charge can remain in units for this time in theory.
mab01uk is offline
post #9 of 28 (permalink) Old Feb 20th, 2010, 05:52 PM Thread Starter
Hi,
Thanks for your help so far
Today I replaced all 4 wiring clips (8 wires) with new spade connectors and re-tried thereset tool to no avail. One thing I note is that the airbag light itself flickers very faintly about once a second (unlike the handbrake warning light which stays on solidly), you have to be very close to notice this.
Just makes no difference - I beginning to think the tool may be at fault...
By the way I ran the reset about 30 times just to make sure and it definately doesnt work! The wires under the seats are not too blame.
Is there anything else I cna do without forking out for proper diagnostic? The light being on is really annoying!
Cheers again
Tom
barki is offline
post #10 of 28 (permalink) Old Feb 23rd, 2010, 07:41 AM Thread Starter
Hi,
Still looking for advice on this if anyone can offer any;
-Under seat connectors have been changed, light stays on despite reset.
-Is there anything else I can do to avoid taking it to a garage and spending £££?
barki is offline
post #11 of 28 (permalink) Old Feb 25th, 2010, 06:55 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Assuming the reset tool is working.......
The other fairly common fault is the seat belt buckle/pre-tensioner, you can pick these up fairly cheaply secondhand and to replace you need to remove the seat (4 Torx bolts). However, I think you have no choice but to have it checked with diagnostics now to narrow down which component of the SRS system is at fault, but I would use a local independant auto-electrician for this as he will be much cheaper than a BMW dealer. Let us know how you get on.
mab01uk is offline
post #12 of 28 (permalink) Old Feb 26th, 2010, 05:42 PM
MJS
MJS's Avatar
United Kingdom View MJS's Chili Red & Black 2nd Gen MINI Cooper S Profile
I had this on a R50 Cooper and R53 Cooper S, both times the dealer replaced the wiring under the seat and reset the computer which cleared and fixed the problem.
I didn't get any more info as they wouldn't give any more, but it solved my problem
MJS is offline
post #13 of 28 (permalink) Old Mar 2nd, 2010, 03:41 AM
Local Time: 06:20 PM
i had similiar issues with my MCS. i undid the connections under both front seats and re-connected them firmly. i then used my peake tool to clear the codes. cleared them about 4 times. then turned off the ignition and then turned on the car. no light since (crosses fingers it stays off!!
mrjasey is offline
post #14 of 28 (permalink) Old Apr 8th, 2010, 09:59 AM
Local Time: 06:20 AM
Australia
Barki,
Have you solved your problem yet. I bought the same tool and tried it tonight and it didn't work for me either. I haven't done anything to the wiring under the seats yet though. I will do that and see how it goes.
Does anyone know if these ebay tools work for the mini airbag reset?
t
tttt is offline
post #15 of 28 (permalink) Old Apr 8th, 2010, 07:16 PM
mab01uk's Avatar
Quoted: 1 Post(s)
mab01uk is offline
Tags: , ,
Airbag Light and B800 reset tool showing code 1 and 15 Skitos First Generation Faults & Fixes 4 May 20th, 2014 11:19 PM
Airbag light reset tool Hollywood First Generation Faults & Fixes 2 Jun 25th, 2013 12:58 PM
Bought a Airbag reset tool on Ebay, but doesn't work, any thoughts? oozhu First Generation Faults & Fixes 4 Mar 13th, 2013 04:55 AM
Airbag Reset Tool off eBay Hiho General Discussion 4 Feb 10th, 2013 03:06 AM
Free use of my B800 airbag reset tool “Wirral Merseyside” 26alan First Generation Faults & Fixes 0 Jul 26th, 2012 01:25 PM
