Mini cooper S r53 headlights - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 1st, 2010, 11:23 AM
Local Time: 03:34 PM
Switzerland Mini cooper S r53 headlights
Hi i am new to this forum and i was wondering if the mini cooper s 2006 model headlights fit on the mini cooper s r53? because they look much better with the projector than my stock ones. thanks.
Old Apr 1st, 2010, 12:20 PM
DaFlake's Avatar
MMC Member
Local Time: 10:34 AM
The 2006 is an R53... However, we need a bit more information. Are you asking if you can swap normal halogens for the Xenon lights or is your car an older model with the flat Xenons and you want the projectors? This makes a difference as the wiring is totally different.
Old Apr 1st, 2010, 06:01 PM
Hi sorry i dont really know what year it is but know minis have see-threw lights, and you can see the projector, like one the new ones, but mine are normal non xenon ones and are not as nice as the new ones, and i want to know if its possible to have the new style headlights with xenon.
Old Apr 1st, 2010, 06:42 PM
MINIAC's Avatar
Canned
Local Time: 07:34 AM
Quote: Originally Posted by mattzia (original)
Hi sorry i dont really know what year it is ...
You can find the build date of your MINI by entering the last 7 digits of its VIN on RealOEM.
Old Apr 1st, 2010, 07:25 PM
DaFlake's Avatar
MMC Member
OK, that helps a little. If you have an R53 (2002 - 2006) MCS, you can swap them out but it won't be easy or cheap as you will have to add the wiring harness, auto level and washers.
Old Apr 1st, 2010, 07:58 PM
Ok great thanks yeah my Mini cooper S is a 2003 model, would it be better to just get the cheap ones on ebay? thanks guys
Old Apr 1st, 2010, 08:00 PM
DaFlake's Avatar
MMC Member
Be careful with that. You need to check with your local authorities and make sure that if you modify the lights without all the proper equipment (levelers and washers) that you will pass inspection. I know in Germany it would fail under TUV.
Old Feb 19th, 2011, 12:18 AM
Local Time: 09:34 AM
Mexico Male
I have sort of the same question but in my case my 2002 Mini Cooper S already has the "flat" HIDs with washers and would love to know if it's a simple swap to the 2006 HIDs. Is that as simple as "Plug-n-Play"???
P.S. I did used the Search engine, that's how I found this thread!
Thanks!!!
Rayan
Tags: , ,
Mini Cooper S R53 vs Mini Cooper S R56 *review* Jeenyus General Discussion 15 Apr 30th, 2010 12:18 PM
New to mini cooper s R53 Martini Maintenance & MINI Care 2 Oct 14th, 2009 06:34 PM
Facelift zenon headlights on an R53 J8YMP First Generation MINI Exterior 0 Feb 1st, 2008 03:35 PM
I want to install neon headlights for my 2005 Mini Cooper Ryanhuaxia First Generation MINI Exterior 3 Jul 21st, 2006 03:07 AM
Mini Cooper Continental Headlights andyferriby General Discussion 7 Jan 7th, 2006 11:56 PM
