Strange Engine Noise maybe?? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 31st, 2010, 04:28 PM
Local Time: 12:04 AM
Australia Male
Australia Strange Engine Noise maybe??
Hey guys, Im kinda new to the Mini world. I just had my 2005 Mini Cooper S Auto for a few months and I think the engine makes a strange noise.
I just recently serviced (oil, filter, air filter, pollen, replaced broken thermostat). If anyone could help, would be a great help.
Old Jun 1st, 2010, 11:04 PM
Local Time: 02:34 PM
Very cool, that you provided an mp3. I downloaded and listened. Its hard to diagnose a problem via sound.
However. I'm no expert, but I have worked with cars in a garage for over 6 years now.
The sound sounds like noisey lifters. They don't sound tooo bad.
What I suggest you do is check your oil level. Take the dip stick and see where the level is at if its low add oil right away.
When is the last time you did an oil change?
Are you using 5w30 synthetic?
There are additives out there that you can add to the oil and take care of noisey lifters. However, I've never used them on a car like a Mini Cooper, or a car that recommends synthetic oil. So I can't really fully recommend those additives unless you hear it from an "expert".
Hope that helps. At least its a start to check your oil, because low levels of oil will dry up the lifters
Old Jun 2nd, 2010, 04:17 AM
I should of read over your OP again before I posted.
It said you recently did an oil change.
Some people who do oil changes like to rush it. By filling it up with oil, check dip stick, and get the car out.
The level of the oil would be fine when first checked, but car needs to run for a bit with new oil then shut off and checked the level again. So there might be a chance that there isn't enough oil in your car.
I've worked in a shop and seen when it was busy, people wouldn't bother turning the car on to check the oil. They just filled it to the top and rolled the car out.
Make sure there is NO oil leaks. I don't know how hands on you are, but put you can lift the car and see if their is any visible leaks.
Otherwise from the sounds of the file you provided I think it's not very major. Does the sound go away as the car starts to warm up after a few minutes? Thats usually when the lifters are well lubricated and the oil is splashing in the top part of the engine.
Old Jun 5th, 2010, 07:26 PM
pistol pete's Avatar
Local Time: 03:34 PM
so unreal..
i was about to post the exact same question......
very very strange..
it does not go away when warmed up.. noise in the same place.. towards the back of the engine as above...
wondered about a noisy injector??
but just checked the oil and it was just above low so might be worth me bunging some more in......
any other ideas.. and thank agondokusumo for posting this so i did not have to
If you make it Idiot proof
They will make a better idiot
Tags: , , , ,
Strange engine noise developed on my 2004 MCS? DCM First Generation Faults & Fixes 0 Dec 1st, 2008 08:10 AM
strange strange noise whilst turning... Nickyrider First Generation MINI Cooper S 7 Mar 7th, 2008 04:32 PM
strange horn type noise from engine workoholic First Generation Faults & Fixes 1 Aug 4th, 2007 06:21 AM
Strange noise coming from my MCS engine. Help! tenderidol First Generation Faults & Fixes 22 Jan 22nd, 2005 06:07 PM
Very strange engine noise! lusomini First Generation Faults & Fixes 9 May 13th, 2004 01:18 PM
