2002 Cooper S Oil Consumption - MINI Cooper Forum
post #1 of 3 (permalink) Old Feb 11th, 2011, 05:19 PM Thread Starter
I'm addicted to the Whine
Local Time: 11:39 AM
Hi all,
Bit of advice required my 02 MCS is using around 1/2 a litre to 3/4 of a litre in a two week period it's done 44k so low mileage for it's age there is an ever so slight hint of blue smoke on initial set off from starting up then nothing.
Engine is not noisy and still pulls like a train.
Could it be valve stem seals?
Any ideas, I have a brand new spare cylinder head but without going to as drastic as changing the head etc I thought id see if you lot had any similar issues / fixes.
Cheers Mike!
Mike Smith is offline
post #2 of 3 (permalink) Old Feb 11th, 2011, 07:03 PM
Valve stems smoke on the over run,so if you give it some welly,then let off the accelerator,if you get bluesmoke out the back it's your valve stems
Wafoo is offline
post #3 of 3 (permalink) Old Feb 20th, 2011, 04:40 PM
Paul@1320's Avatar
Local Time: 10:39 AM
If its not coming out of the rear main oil seal we have seen a common problem with the piston rings loosing tension, espically in early cars.
Paul@1320 is offline
Cooper S Oil Consumption Argyle Girl Second Generation MINI Cooper S 33 Jul 6th, 2011 06:20 AM
Cooper S Oil consumption snake_eyes First Generation MINI Cooper S 5 Dec 7th, 2010 09:48 AM
Fuel Consumption (uk) for Cooper S dave0098 First Generation MINI Cooper S 6 Oct 13th, 2009 08:55 PM
Fuel Consumption On A Mini Cooper LouieCoop First Generation MINI Tuning 12 Jan 31st, 2007 09:04 PM
Fuel consumption for a Cooper S rovervitesserrdcom First Generation MINI Cooper S 59 May 9th, 2006 05:40 PM
