Strange Engine Sound below 2000RPM - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 10th, 2011, 12:08 PM
Local Time: 12:35 AM
Australia
Australia Strange Engine Sound below 2000RPM
All,
I just had a 2006 Cooper S go in for a replacement clutch and flywheel, and on return it sounds very rough below 2000rpm, akin to a spluttering tractor.
From the driver seat, it sounds as though you've changed into far too low a gear, even in first from take off. As the revs hit 2000, the engine suddenly becomes smooth. The same with 2nd. The only other way I could describe it would be to say below 2000rpm it sounds like a diesel, or as if something is rattling or lose.
Has anyone got any suggestions?
The mechanic thinks there is nothing wrong, and a trip to BMW came back with the same answer.
Old Jun 3rd, 2011, 12:19 AM
Local Time: 02:35 PM
Canada Stop driving your mini and change your timing chain tensioner immediately
I find it incredible that your mechanic and dealer told you all is good.
Does this sound familiar?
Start the car, all is good, drive for a minute and then the car starts to rattle like a diesel tractor at idle? Rev it up to 1500 rpm and the rattle starts going away, above 2000 rpm all is smooth....how am I doing so far?
Well I did make an appointment to have it checked out but kept driving my r53 in the meantime....tensioner went, timing chain chewed up my oil pump....set me back $2500 in labor and parts...ended up paying close to $4 because once everything was taken apart I decided to install many new components.
don't want to make you paranoid but had I just changed the tensionner, I would've only had to pay about $500. $4k hurts, even if I have a bunch of new components under the hood now.
that's my 2 cents.
Tags: , , ,
Strange engine sound Ingrid First Generation MINI Cooper S 8 Nov 24th, 2009 02:22 PM
Strange Sound!! Dainesy Wheels, Tyres & Brakes 2 Dec 14th, 2008 07:41 PM
Strange sound djwoody First Generation MINI Cooper S 6 Oct 9th, 2006 09:00 PM
Strange sound coming from engine compartment Dirk First Generation Faults & Fixes 2 Aug 11th, 2005 06:15 AM
strange metallic sound miniads First Generation Faults & Fixes 5 Feb 22nd, 2004 06:49 PM
