Supercharger Failures - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 21st, 2011, 05:06 AM
Local Time: 01:35 AM
Australia Female
Australia Supercharger Failures
I am the proud owner of a 2005 Cooper S Convertible with 85,000km. I have had this car for about 9 months and I love it!
The bearings in the supercharger have worn out and I am having to replace the WHOLE supercharger at considerable cost and also no car for several weeks while we wait for parts.
Has anyone else had this problem?
Old Jul 21st, 2011, 11:19 AM
BRGJCW's Avatar
Local Time: 12:35 AM
Australia Male View BRGJCW's British Racing Green & White 1st Gen MINI Cooper S Profile
This sounds very odd. I thought it would be at least 160,000 klms before the supercharger needed this sort of work (if at all). I have just over 105,000klms up in a 2002 S. Are you sure this is the problem? What symptoms are you having?
Old Jul 21st, 2011, 11:42 AM
mab01uk's Avatar
Local Time: 03:35 PM
Average life of a Supercharger is about 120,000 miles although some of course fail earlier and some much later than this.
I have had the very similar Eaton S/C fail on a Mercedes C200K at 110,000 miles when it became noisy through wear in bearings.
This article describes 2002-2006 MINI Cooper S Supercharger Oil Service:
https://wiki.bentleypublishers.com/d...er+Oil+Service
Old Jul 21st, 2011, 09:50 PM
Australia Female
it is definitely the problem as the mechanic has pulled it apart and we can see where the bearings are worn. Costing $5, 500 to repair!!!!!!!!!
Is it worth letting Mini know?
Old Jul 21st, 2011, 10:46 PM
mab01uk's Avatar
Worth a try with MINI for a 'goodwill' offer........nothing to loose.
My Mercedes Supercharger which is very similar to the Mini one, cost £1000 (UK) for a new S/C unit + a couple of hours labour to fit.
With Mini's in the UK it is often possible to source a good low mileage used replacement supercharger at a much lower cost than new.
Old Jul 22nd, 2011, 08:22 AM
Australia Female
I have read a few posts that have mentioned the goodwill offer. What is it and how do you do it??
Thanks for your replies, it is very frustrating to spend so much money on what is a relatively new car.
Old Jul 22nd, 2011, 12:06 PM
mab01uk's Avatar
You have to submit details of the problem and your Mini's history, mileage, etc with a request for 'goodwill' via your local Mini Dealer.....or ask them for a contact number/person for you to get in touch direct with the relevant department at MINI HQ.
Old Jul 24th, 2011, 12:01 AM
BRGJCW's Avatar
You'll also probably need proof of a service history (regular oil changes etc...). Did the car come with the service history? Was it serviced by BMW/Mini or a different service company (Ultra tune or similar)?
I'd be going back to the dealer you bought it from initially but if you bought privately then there is no comeback on the seller unforetunately.
Good luck with it and once reparied at least you will know that it will be fine for quite some time.
Old Jul 24th, 2011, 12:19 PM
Australia Female
Thanks for that info, I am not sure whether I will go down that track yet.
I have been told that this is not an unusual problem. Has anyone else had their supercharger fail at such low kms (85,000)????
Several failures in a few days mini_viajero General Discussion 0 Dec 3rd, 2009 02:17 AM
Two motor failures, coincidence? Rachy22 First Generation Faults & Fixes 2 Mar 26th, 2009 01:38 PM
Koni FSD Failures mdreuben First Generation MINI Suspension 17 Mar 14th, 2007 09:57 PM
VARIOUS Power Failures CanberraCooperS First Generation Faults & Fixes 4 Jul 21st, 2004 04:51 AM
Failures after 30.000 KM Cooper i Do First Generation Faults & Fixes 1 Dec 30th, 2002 05:56 PM
