| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
Knock/bang on gear change Hi all, I have recently bought a 03 MCS, however when you change gear I'm getting a knock/bang from what sounds like a mounting for the engine. Is there a common issue with a particular mount? If so are there any uprated replacements? Any advice would be good as don't want to throw money at parts that don't need swapping! Cheers Gav |
| I had the same problem on my normally aspirated Cooper yesterday - turned out my left hand engine mount bracket had suffered a fatigue failure with the crack widening and widening. Luckily it didn't let go completely. I was convinced the clunk was my CV joint - how wrong was I. A company called Masterdriver sorted it out and the clunk has gone away. I'm well chuffed and I suggest you check your mounts carefully. I have the harsher sports suspension plus and the 16 inch rims that probably started the problem. Good luck |
| Faint 'knock' when taking up torque, then 'knock' when releasing? | Faxo | First Generation Faults & Fixes | 3 | Aug 16th, 2011 07:51 PM |
| 2007 MINI COOPER R56 sticky gear change 1st to 2nd gear | hankdu | Second Generation MINI Cooper | 1 | Aug 31st, 2008 08:17 PM |
| 1st gear accelerating, single knock. | mini_mart | First Generation Faults & Fixes | 0 | Feb 8th, 2008 02:23 PM |
| When to change gear?? | wee rocket | General Discussion | 17 | Jul 21st, 2005 02:02 PM |
| Jerky gear change from 2nd gear | stellablade | First Generation Faults & Fixes | 7 | Sep 29th, 2002 11:58 PM |
