Abs, traction control and run flat lights all on?!?!? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 9th, 2012, 02:24 PM
Local Time: 06:53 AM
Hi guys, I'm new to the forum so forgive me if this is in the wrong place.
I have a 2004 mini cooper s. just done the brake pads and wear sensors front and rear, just over a week later and I have the traction control light, the abs warning light and the run flat indicator all on at the same time. This seems to clear for a while after stopping for a short time but then comes back on whilst driving. I have read that this may be due to a faulty wheel speed sensor and just wondered if anyone can confirm this? I'd rather not take it to the dealer as money is tight. Anyone's else had this problem? Help :-(
Old Apr 10th, 2012, 11:39 AM
mab01uk's Avatar
Local Time: 07:53 AM
Almost certainly as they are all linked to readings from the wheel speed sensors........also as you did the brakes recently I would check around each wheel hub for any dirt or misalignment affecting a sensor.
Tags: , , , ,
ABS, Traction control & Run flat light then come on orange. Tommy31 Welcome New Members 5 Nov 20th, 2011 11:23 AM
ABS, Flat Tire, Traction Control Warning Lights bajan06 First Generation Faults & Fixes 3 Jul 7th, 2011 08:19 AM
Abs/traction control/tyre pressure lights on? ccj09 First Generation Faults & Fixes 2 Jan 22nd, 2011 01:11 PM
Desperately Needing Some Technical Help with Engine & Traction Control warning lights johnaspence First Generation Faults & Fixes 9 Nov 21st, 2009 02:46 PM
ABS, Traction Control & Run-Flat Light All On? Tallpaul First Generation Faults & Fixes 1 Aug 12th, 2009 08:49 AM
