How about instead of letting the useless headlight washers just sit there, re-route the nozzle to the intercooler (S only, sorry!) and get some nice cool water on the surface. Like a slow NOS system, but at least it's free!
Brian
If you don't like the way I drive, get off the damn sidewalk!
That is a clever idea. I have heard of some VW GTI's that have their rear window washer set up to do this for the turbo intercooler.
Has to be helpful with the heat-soak, but you probably should switch to distilled or purified water rather than washer fluid.
And that's kind of what I've been wondering, whether it's washing fluid in there, or just regular water. It doesn't look like washer fluid, but I guess it would be wise for me to check. I would like to do this for autocrossing, but there would need to be a way to not have the windshield washers go on at the same time. This would be much easier to do than spraying water on the intercooler after every run. I don't think I would have to use it on the course, since the runs rarely exceed a time of over a minute.
Brian
But the thing is, I won't be driving the MINI in the snow. Don't want all that salt from lake effect snow in Ohio. Might drive the Miata, or the Jeep. So the only use I have for the washers doesn't apply to me. I took a look under the hood today, and realized it may be more work than it's worth. Instead I might just use a pressure washer filled with ice water. At least it would colder.
Brian
As long as you are in a relatively cooler climate, the ambient temperatures for most of the year will cool the intercooler very well as is. I am sure that the BMW engineers worked hard to ensure that the intercooler does its job most of the time.
But I would like to see someone figure out a way to do this, just for the uniqueness factor!
I'm not convinced that it would help. If you have a look at the intercooler on the S, it is clearly designed with flow rather than maximum cooling in mind.
Good link. However this is for water injection into the combustion champer, not for spraying water over the intercooler to bring charge temperature down. I think water injection by the headlight washers would be a little amusing.
