URGENT!!! Fuel filter trouble! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 8th, 2012, 03:57 AM
Local Time: 03:44 AM
Need desperate help! Pulled the fuel filter to inspect and after placed the filter back in and secured it. Now I cannot get the car to start. I have checked the fuel pump fuse and it is fine. Rechecked the fuel filter to ensure it was properly secured. Disconnected and reconnected the battery. But still wont start.
Old Oct 31st, 2012, 11:39 AM
Local Time: 09:44 AM
Did you reconnect the connector for the pump on top of the filter housing?
Old Nov 7th, 2012, 01:59 AM
CCroker's Avatar
Local Time: 04:44 AM
United States Male
Check your connections as the hoses can be mixed. Make sure the housing is tight. Is the motor turning over? Is the pump making a sound?
Charlie Croker ,BRG 03 Cooper S, SCCA Solo, PDX, Time Trials, RoadRally, and Stella, 011 Oxford Grn Countryman S
Old Nov 7th, 2012, 02:05 AM
Online
Local Time: 10:44 AM
Did you prime the fuel system?
To do so you need to put key in ignition and switch to the one before cranking the car (position 2 I think), wait a couple of seconds, then switch key back to off, then to position 2 again - repeat 10 times.
Have a read here:
http://www.northamericanmotoring.com...hange-mcs.html
There's a few people who had the same trouble and a few solutions.
Tags: , ,
