Hissing noise under load. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 20th, 2012, 03:30 PM
Local Time: 01:41 AM
Wonder if anyone has has this problem, I'm hearing a hissing noise from under the bonnet when I accelerate. I can hear the usual supercharger whine but then a hiss comes in. I've tried to make the noise when parked up and reving the engine but it only seems to happen then I'm driving. Sounds like a leak but I'm not sure if its some sort of release valve.
Old Nov 20th, 2012, 04:04 PM
Local Time: 02:41 AM
Hi ya
Is it a standard MCS if so
Remove the intercooler cover only 4 torx screws
Have a good look at the rubber intercooler boots, make shore there fitted properly and are not split. You can run the car as well see I you can here it hissing with the cover off.
Do the brakes feel ok ?
Also check your spark plugs they have Tendency to come undone, so while your there always worth checking
Hope this helps
Old Nov 21st, 2012, 01:31 PM
Yes it's a standard MCS. I will give that a try, I does sound like a leak of some sort. Yeah the brakes are fine. Why ask, Could it be a braking issue? It's only when I put my foot down not brake
Old Nov 21st, 2012, 01:42 PM
I think they were referring to the fact it could be a vacuum leak at the brake servo or servo hoses from the vacuum pump on the engine.
Old Nov 21st, 2012, 03:57 PM
Ah right, as far as I can tell they are fine. Think I'm going to have to take it somewhere to get checked out. Last thing I want is the supercharger going or something like that. Anyone recommend a mini specialist or decent place to go in the Newcastle area?
