Coolant leak - MINI Cooper Forum
Go Back   MINI Cooper Forum > Model Specific MINI Forums > MINI Cooper S > First Generation MINI Cooper S
coolant leak Bulldog64 Welcome New Members 2 Dec 1st, 2013 09:54 AM
Coolant leak 2007 Cooper paulmclean General Discussion 2 Oct 1st, 2013 09:02 AM
Coolant leak & Oil usage Zanhar 25 Second Generation Faults & Fixes 13 Sep 27th, 2013 05:24 PM
Coolant leak advice Bissell First Generation Faults & Fixes 3 Nov 6th, 2012 10:46 PM
Cooper s coolant leak - R53 Aaron_burr First Generation Faults & Fixes 3 Oct 22nd, 2012 02:41 PM
Old Dec 27th, 2013, 07:21 PM
Local Time: 12:30 AM
England Male
England Coolant leak
Hi,
Need some serious advice please.
Apologies for a massive post but wanted to be as thorough as possible.
Driving along normally this afternoon, joined a dual carriageway and gave it a bit of right foot. Suddenly, a load of what looked like white smoke from the exhaust. It went away and everything seemed normal. Carried on driving for about 1.5 miles to the end of the carriageway and as I was slowing down another puff of white smoke from the back and also the front?
Kept driving, now really conscious of everything trying to figure out what happened and then came to some lights, noticed my temp gauge rapidly rising. It got to about three quarters up before I decided to pull over and kill the engine.
It was now apparent, that it was steam and not smoke.
Popped bonnet, coolant everywhere but couldn't tell where from exactly... Got someone to drop off a load of water, filled up tank but water just came straight out!
Couldn't tow the car as the towing eye was missing so eventually had to shell out 108 for Green Flag to come out.
Two hours later, the guy arrives and quickly spots that a hose near the top,of the engine on the right hand side as you're looking at it had blown off its connector because someone hadn't attached the hose clip at all (so could've blown off anytime).
Anyway, he couldn't fix it because he would've had to remove the air filter box etc to get access which he couldn't do. He secured the hose back on with a cable tie, filled it up and the car started fine with no coolant loss as far as I could tell as a temporary fix so I could do it myself tomorrow or whatever.
I drove home fine, the temp gauge was much lower than normal but I turned on the heater which just blew out cold air for ages then warmed up and the gauge rose to its normal point (just above halfway).
What I would like to know is whether that short drive between the puff of "smoke" and killing the engine off is likely to have caused any damage?
As I say, it drove perfectly and the temp gauge wasn't even at max when I shut it down....
I'll be sorting out that hose clip in the morning - is there anything Obvious that I can check to see if it's knackered?
Any assistance would be appreciated!
Old Dec 28th, 2013, 08:42 AM
I had a similar problem to you, except when my mini went in for it's service someone hadn't put the coolant cap on tight enough. It may have been loose. For a few days after I noticed steam rising in front of my windscreen. At first I didn't think anything of it as steam quite commonly rises out of the bonnet when wet. But it happened again, when it was dry. When I arrived ay my destination I checked the engine, and before I even got there, the engine fan had come on, which has never happened before when the engine is turned off. This time, I didn't notice anything wrong either. When I got home that night, the engine fan came on again and it was only this time, under the garage lighting, that I noticed there was a load of green splash marks around the coolant housing. There was still steam and liquid coming out of the coolant area. When it cooled down, I then saw that the coolant cap was very loose. I drove straight to the mini garage the next day and on the way the engine temperature increased fast and almost hit the red line when I arrived at the mini garage, probably due to the lower speed and less air flow.
Following this, mini topped it up with coolant and made sure the cap was properly closed this time. Since this, I haven't had any problems with the coolant or the engine.
However, the engine revs do shake a bit when idle and warm, but this was happening before the coolant problem.
Mini Coolant and Fan - YouTube
The Following 2 Users Say Thank You to Kalenshah For This Useful Post:
Old Dec 28th, 2013, 04:22 PM
mab01uk's Avatar
Online
Should be ok when coolant suddenly leaks it turns to steam because system is pressurised but the cool heater afterwards suggests there is air in the system which needs bleeding out (lots of posts on here about bleeding cooling system if you search)......important this is done or coolant level will drop and engine overheat again. Heater will blow hot when all the air is gone.
Old Jan 5th, 2014, 06:55 AM
England Male
Thanks to you both. Sorry for late response (been away for a few days)
I sorted out the hose the next day - a right pain in the back side haha - had to remove the whole air filter box etc just to access the hose! Anyway, that's all done. No leaks!
I did read up about bleeding the system but here's the thing - I loosened both the bleed valves (top of rad and the one near the hose I'd just sorted) but absolutely nothing came out - air OR coolant?
The car was right up to temperature, there were no leaks etc but yet even after about 15 mins of idling I had nothing from the bleed valves. I made sure I had the heater set to 'HI' and on the lowest speed as directed but still nothing.
Any suggestions?
I also read somewhere yesterday that when bleeding the system that the rear of the car needs to be lower than the front when bleeding. Haven't tried that but will do later hopefully.
The heater seems to be about right i think (I never really paid any attention to what it was like before but it's warm enough for me so I think it's ok)
If you can think of anything I,d be really grateful.
Thanks again fella's
Old Jan 5th, 2014, 08:44 AM
mab01uk's Avatar
Online
The bleed valves may be blocked, perhaps someone used a 'Radweld' type additive in the past which can sometimes do this.......however if your heater is blowing hot and the coolant level is stable in the expansion tank and no sign of overheating on the gauge you may be ok and no air is trapped. Just keep an eye on coolant level and temperature gauge for next few days during and after any journey and perhaps carry some extra coolant/water for an emergency 'get you home' top-up if required.
Old Jan 5th, 2014, 10:19 AM
England Male
Thanks, mate. Just managed to bleed it a little, hopefully. Parked the car facing uphill, turned on heater like before and let it idle with the rad cap on but opened the bleeder by the top hose until the temp gauge showed to halfway. Noticed coolant trickling out so closed the valve off and let it idle for another 5 mins or so. No leaks, temp gauge stayed stable, shut off engine and opened rad cap to see level was a little low which makes sense so topped it off. Will keep an eye on the coolant level and re-check next weekend.
Thanks again.
Tags: , , ,
» Recent Threads
How to Retrofit the Spacesaver Spare Wheel
Dec 6th, 2011 10:40 PM
by mab01uk
Last post by mab01uk
Today 10:25 PM
46 Replies, 29,527 Views
Trunk Handle Cover
Today 02:39 AM
by iamtony
Last post by whaap
Today 09:23 PM
4 Replies, 142 Views
2007 Cooper D (r56) - weird sound. Maybe clutch?
Today 07:01 PM
by hyvrid
Last post by hyvrid
Today 09:20 PM
2 Replies, 78 Views
Facelift ('05) Confusion
Today 05:26 PM
by Triang
Last post by JohnnyC
Today 08:58 PM
6 Replies, 132 Views
2007 Cooper D (r56) - How to look after her and what to look for when buying
Apr 15th, 2014 01:10 PM
by hyvrid
Last post by hyvrid
Today 08:11 PM
7 Replies, 421 Views
O2 sensors in exhaust
Apr 18th, 2014 06:03 PM
Last post by Invernessguy
Today 07:22 PM
4 Replies, 228 Views
Mini One dipstick
Apr 14th, 2014 04:22 PM
by pooz23
Last post by drozd
Today 07:06 PM
6 Replies, 269 Views
High Mileage 152k miles - Mini One 04 plate
Jan 31st, 2014 09:43 AM
by raym
Last post by Triang
Today 05:46 PM
8 Replies, 1,413 Views
Facelift One ('05) Confusion...may have posted in wrong place sorry!
Today 05:37 PM
by Triang
Last post by Triang
Today 05:37 PM
0 Replies, 105 Views
Mini Identification
Today 10:23 AM
Last post by subframe
Today 05:21 PM
8 Replies, 171 Views
Roof Rack
Today 03:17 PM
by vnutz
Last post by vnutz
Today 03:17 PM
0 Replies, 79 Views
Will this rear bike rack work on the Clubman?
Jun 6th, 2011 10:18 PM
Last post by tina
Today 07:40 AM
4 Replies, 4,034 Views
Mini Cooper S Rebuild
Apr 18th, 2014 07:49 AM
Last post by tina
Today 07:39 AM
1 Replies, 181 Views
R52 A pillar interior trim removal
Apr 18th, 2014 08:11 AM
Last post by tina
Today 07:39 AM
4 Replies, 216 Views
can anybody tell me what this is
Apr 15th, 2014 08:02 PM
by Jon g
Last post by tina
Today 07:38 AM
2 Replies, 302 Views
MINI of Burlington
Mar 30th, 2014 08:59 PM
Last post by tina
Today 07:37 AM
1 Replies, 304 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by tina
Today 07:36 AM
8 Replies, 741 Views
Cup holder inserts
Apr 18th, 2014 06:23 PM
Last post by tina
Today 07:35 AM
5 Replies, 252 Views
Should i buy a Mini Cooper r50
Feb 14th, 2012 01:09 AM
by MENESS
Last post by Milpol
Today 12:58 AM
13 Replies, 7,974 Views
Replacement driver side door handle **new member**
Apr 14th, 2014 10:32 PM
Last post by The Nun
Yesterday 06:43 PM
3 Replies, 283 Views
Wheel & Tire Center
