RPM Jumps from 3K to 4K - MINI Cooper Forum
post #1 of 2 (permalink) Old Jan 20th, 2014, 09:44 PM Thread Starter
Local Time: 07:22 PM
Hello all,
In the past month or so I've noticed some weird behavior out of my car. 2006 Mini Cooper S with only 57K miles on it (Automatic).
Scenario 1 - Driving in D accelerating at a normal pace the RPM's spike rapidly from 3K to 4K and the car almost sounds like it's redlining. Once it hits 59-60MPH it drops back down to 3K RPM and the rest of the acceleration is normal.
Scenario 2 - Cruising on the highway at about 70+. Normally start taking the foot off the gas to slow down with traffic and when my speed drops to about 60MPH the RPMs spike again from around 3K to about 4K. When the car gets below 60MPH the RPMs drop again.
Scenario 3 - When I'm braking to stop the car, the RPM goes down to about 1K then when I'm about to come to a full a stop, the RPM spikes up and goes back down.
Does anyone have any idea what's going on. Maybe someone experienced this also. Someone told me that I could try changing my transmission fluid and that might help.
mc vovan is offline
post #2 of 2 (permalink) Old Jan 8th, 2016, 06:15 AM
Local Time: 12:22 AM
Smile Same Problem
Hello! I'm experiencing the exact same issue with my 2006 Automatic Mini Cooper. Did you find a solution to this problem? If so, please let me know.
gwok is offline
2006 Cooper: RPM to Gear Ratio rphox2003 First Generation MINI Tuning 1 Sep 3rd, 2015 04:00 PM
RPM drop when starting , 3 times in a row! omri617 Maintenance & MINI Care 17 May 14th, 2013 07:40 PM
Issue at 3000 rpm JohnMead MINI Cooper Diesel 9 Apr 27th, 2013 04:09 PM
2007 MCS Cold start rattle under load. Specific rpm. JGrimshaw Second Generation Faults & Fixes 3 Nov 22nd, 2012 06:27 PM
What RPM do you start 1st with? thewhitenight000 First Generation MINI Cooper 2 Aug 8th, 2012 06:19 AM
