New Mini Owner - Clunk Noise from Rear - MINI Cooper Forum
post #1 of 4 (permalink) Old Jan 28th, 2014, 03:46 AM Thread Starter
Local Time: 11:31 PM
Hello All,
Just purchased my first Mini Cooper S 2005 over the weekend and picked it up today. When I did the test drive in a neighboring city did not hear any clunking or knocking from the rear end. San Francisco where I live unfortunately has 3rd world roads, and now I hear a clunk. I own other BMW products (E46 2003 330cic) and know that suspension bushings can cause tons of noise.
From a quick search on this forum I see that top mounts can cause clunks. The previous owner just replaced the front struts and mounts, so I suspect they're cool. Other than the mounts, what typically can cause this noise in the rear. I noticed that at low speeds if I turn hard in one direction it will clunk.
I can make the knock / clunk happen when I compress the rear end then release.
Any ideas? I'm sure that I'm going to be very active on this board, so please be nice... Cheers...
robt_sf is offline
post #2 of 4 (permalink) Old Feb 10th, 2014, 02:13 AM
CCroker's Avatar
Local Time: 06:31 PM
Quoted: 27 Post(s)
United States Male
Front was replaced, why not rear, they are easier to replace.
Charlie Croker ,BRG 03 Cooper S, SCCA Solo, PDX, Time Trials, RoadRally, and Stella, 011 Oxford Grn Countryman S, with complete Sport Package, stock at present
CCroker is offline
post #3 of 4 (permalink) Old Feb 10th, 2014, 11:10 AM
Local Time: 10:31 AM
Australia Male
Hey RobT, not sure if its the same noise we were hearing but...
Our 2002 Mini Cooper S that we bought second hand had annoying rattles coming from the rear that drove us crazy whenever we drove it around. It was more medium rattle/tapping sound than a heavy clunk though. We checked the rear suspension out but couldn't fault it.
After much trial & error we determined it needed 2 separate repairs to make everything silent again:
1) Replaced the anti-rattle clips in the rear brake calipers (I think the mechanic actually replaced the brake pads with new OEM versions to achieve this). Oddly, it was only the left rear brake pads that were rattling - the right-hand rear pads were fine.
We had a definite improvement once the brake pads were changed.
2) Replaced the bottom part of the boot latch mechanism (wrapping some insulation tape around the tongue of the bootlid latch helped isolate the noise too for a while). Try to shake the bootlid up and down when its closed. If it clunks, either the latch is worn or it needs some adjustment on the bump stops.
After both repairs were done there were no more rattles.
Our 2006 MCS needed the same bootlid latch repair as well.
Hope this helps & good luck finding your clunk. :-)
Cheers - JJ.
jj-snax is offline
post #4 of 4 (permalink) Old Feb 10th, 2014, 11:35 AM
Hi ya
Rear Anti roll bar mounts :-) cheep easy quick to change
Hope it help
marque is offline
Mini R56 Slow Speed Clunk From Rear When Cold gaznav Second Generation Faults & Fixes 1 Nov 20th, 2014 05:38 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 05:36 AM
Brands Hatch Mini Festival 22/23 June 2013 mab01uk Mini Events 20 Jun 23rd, 2013 10:03 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 06:11 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 05:29 AM
