B800 tools - MINI Cooper Forum
post #1 of 2 (permalink) Old Feb 14th, 2014, 06:48 PM Thread Starter
Local Time: 03:32 PM
England Male
B800 tools
It's a long shot but here goes....
Since I've owned my 02 R53, the airbag light comes on. I bought a B800 tool and that's reset it loads of times. The error code it always throws up is 10/03 - passenger pre-tensioner.
Done all the usual stuff and finally got it sorted (I thought) about 3 wks ago when I re-routed the wiring and tightly secured the wiring (in bubble wrap for added bump protection haha) - it hasn't been on once.
Til today.
However, I suddenly thought, my drivers seat was moved today only a short while before the light came on - could the manual actually mean the drivers side tensioner? Assuming its a manual for LHD cars?
It'd be better if it actually said LH or RH side but instead, it refers as drivers side / passenger side...
Logical conclusion or clutching at straws?
Hollywood is offline
post #2 of 2 (permalink) Old Feb 14th, 2014, 08:22 PM
mab01uk's Avatar
Local Time: 02:32 PM
Quoted: 1 Post(s)
Possible I guess....
If not the wiring the seat belt pre-tensioners can also cause problems when they wear internally or get dirt in the contacts as you buckle up.
mab01uk is offline
Tags: , , ,
Airbag Light and B800 reset tool showing code 1 and 15 Skitos First Generation Faults & Fixes 4 May 20th, 2014 11:19 PM
What scan tools are you guys using? brownstripe Maintenance & MINI Care 2 Dec 16th, 2013 01:09 AM
Sourcing Special Tools peterSu Maintenance & MINI Care 1 May 2nd, 2013 12:47 PM
Free use of my B800 airbag reset tool “Wirral Merseyside” 26alan First Generation Faults & Fixes 0 Jul 26th, 2012 01:25 PM
