Cooper S with blown engine Options??? - MINI Cooper Forum
post #1 of 15 (permalink) Old Mar 4th, 2014, 08:36 PM Thread Starter
Local Time: 04:20 AM
United-Kingdom Cooper S with blown engine Options???
Hello new to the forum and to the mini world, ive just bought a 2003 mini cooper s Lohan tuned. I bought it with a suspected head gasket failure but on removing the head tonight one of the pistons is knackered and scored the bore in the process.
whats my options on oversize pistons? cheapest place to shop?
any help would be great
johnd-mkiv is offline
post #2 of 15 (permalink) Old Mar 4th, 2014, 10:05 PM
mab01uk's Avatar
Local Time: 03:20 AM
Quoted: 1 Post(s)
Bmminiparts are worth checking for new online parts:
www.bmminiparts.com - Home
Good new & used parts, engines, panels, etc try these specialist Mini Breakers:
MiniMatt|BMW|MINI|Modifications|Parts|Spares|Servi ce|Tuning|Repairs|Racing
Mintech Spares UK- mini breakers uk - Mintech Spares UK BMW Mini Parts
Home | BMW MINI Spares New and Used - BMS Direct LTD
Tuning Parts:
1320
MINI - Servicing - Repairs - Tuning - Parts - Spares
Lohen.co.uk - Track & Fast Road Performance for your New Mini - Home
mab01uk is offline
post #3 of 15 (permalink) Old Mar 5th, 2014, 10:39 AM
Hi ya
Was the piston damage caused but destination or running lean can you post a pic
Pull the engine get it rebored and oversize pistons, there's lots of options for pistons depends on budget buy the best you can if your going to drive it hard.
Get a full gasket set victor reniz these are what mini use but 10x mark up, call express car parts one of the only places I have found that sell them.
http://www.expresscarparts.co.uk/productresults.php
Soon as it's back together and run in you need to get it on the dyno get the air fuel ratio checked.
Also while you gave it in bits check you vacuum pipe from you fuel press regulator to your Intake manifold this will cause what you have described
Or the quick option engine swap as mab says make shore you get a W11 not a W10 engine
Hope this helps
marque is offline
post #4 of 15 (permalink) Old Mar 5th, 2014, 12:27 PM Thread Starter
Thanks for your responses, I've had a ring about and seems number 3 piston in prone to failure, the bore is scored but if the option of oversize pistons are about then this is going to be the way forward.
I looked into secondhand engines but these are high mileage an probs no better off.
Best I've found at the moment are wiseco forged pistons .50 oversize for around 300 in America so I guess with duty ect looking at 400
This wAs only meant to be my run about now turning into a big project
post #5 of 15 (permalink) Old Mar 5th, 2014, 07:17 PM
Hi ya
Piston wise you have a few choices JE, CP, Mahle, wossner. Mahle are the standard ones if your not going to go made with power they will be ok to use.
Just make shore you get cooper s ones as the coopers are different co p ratio.
Hope this helps
marque is offline
post #6 of 15 (permalink) Old Mar 5th, 2014, 07:25 PM Thread Starter
thanks ive found a few sets of pistons am I right the engine has a compression ratio of 8.3:1?
ive seen some at 8.5:1 are any running this ratio?
thanks
post #7 of 15 (permalink) Old Mar 5th, 2014, 08:52 PM
Hi ya
Yes 8.3:1 is correct for r53, 8.5:1 will be ok :-)
Hope this helps
marque is offline
post #8 of 15 (permalink) Old Mar 6th, 2014, 05:49 PM Thread Starter
Cp forged pistons ordered �� any other things to look out for or do while engine and box are out?
post #9 of 15 (permalink) Old Mar 6th, 2014, 08:26 PM
Hi ya
It depends on your budget, there are lots of things you can do :-)
Me personally if the milage is high I would do the timing chain guides and tensioner.
May be swap out the oil pump always a good idea, melling make the pumps for bmw mini last pump I bought I got the complete pump and cover assy for about 40.
http://www.ebay.co.uk/itm/Brand-New-...item1c3d06cdf7
Victor reinz make the gaskets for bmw mini
Fit a set of ARP head bolts and rod bolts and cam bolt.
Check your supercharger belt tensioner the damper fails Express car parts sell the complete assy check you idler pulleys to.
May be replace the clutch plate oem or kavs, guide tube and thrust bearing.
Change the gear box oil.
fit magnetic oil drain to the engine sump (dimple)
Check and change the super charger oil both ends
Make shore you use the correct antifreeze halfords sell it in concentrate of mixed
Halfords | Comma G48 Antifreeze and Coolant RM 5L
Plenty of clean products gallons of the stuff red scotch bright
Blimey I could go on :-)
Hope this has helped and not put you off :-)
marque is offline
post #10 of 15 (permalink) Old Mar 6th, 2014, 10:43 PM
mab01uk's Avatar
Quoted: 1 Post(s)
R53 Mini Supercharger Service guide:
https://wiki.bentleypublishers.com/d...er+Oil+Service
mab01uk is offline
post #11 of 15 (permalink) Old Mar 17th, 2014, 08:36 PM Thread Starter
Thanks for all your help much appreciated, pistons have arrived will do a build thread if people do that on this forum?
post #12 of 15 (permalink) Old Mar 17th, 2014, 09:55 PM
Hi ya
Yes mate plenty of picture and how to :-) always handy for others.
When you pull the rods and pistons out, watch out for the oil squirters take not of the position digital picture.
Keep use up to date if you need a hand or info just shout
marque is offline
post #13 of 15 (permalink) Old Mar 20th, 2014, 09:58 PM Thread Starter
do you know where I can get the bolt torque specs from?
main bearing
big end
cam
ect
thanks
post #14 of 15 (permalink) Old Mar 20th, 2014, 11:09 PM
marque is offline
post #15 of 15 (permalink) Old Mar 21st, 2014, 10:02 AM Thread Starter
That's perfect thanks
Mini Cooper s engine issues jakvette General Discussion 0 Feb 12th, 2014 06:49 PM
Sensible Advice and Thoughts on Blown Engine Nikward First Generation MINI Cooper S 4 Jun 6th, 2013 01:52 PM
Oil consumption Mini Cooper s N18 engine peterhellawell Maintenance & MINI Care 1 Jan 24th, 2013 09:11 PM
