I think the timing chain tensioner has gone bad. - MINI Cooper Forum
post #1 of 3 (permalink) Old Mar 12th, 2014, 02:06 AM Thread Starter
Local Time: 07:01 PM
Exclamation I think the timing chain tensioner has gone bad.
I've only had the car a month and it just hit 81,000 miles today. It has had a little noise on startup since biting it but I thought it was just injectors. Today it got very loud when I started it and never stopped. After looking around on line it seems as though the timing chain tensioner has gone bad. The car sounds like a diesel almost it's so loud. Any ideas what it costs to take the car to the shop and have repaired, or is it easy enough for someone skilled to do it themselves?
I'm trying really hard not to get bummed out over this.
ga_mini is offline
post #2 of 3 (permalink) Old Mar 12th, 2014, 08:37 PM
Local Time: 12:01 AM
i had this happen a few weeks ago.
Car starts to sound like a tractor..! it cost 98.00 to get repaired, good i thought.
What i would say is get it done asap, this is a common fault also associated with lack of oil and if left can cause more internal damage.
Make sure you check your oil weekly, which I'm sure you know.
good luck.
masterhalifax is offline
post #3 of 3 (permalink) Old Mar 13th, 2014, 12:17 AM
Hi ya
Check your spark plugs are in and tight they do come out
If it is your cam chain tensioner it's an easy job little fiddly but ok post 11 will help you
Instructions for replacing Timing chain tensioner? - North American Motoring
Hope this helps
marque is offline
2007 Cooper S "Timing Chain Tensioner Defect" igooba Australia 24 Sep 26th, 2016 09:04 AM
Mini Cooper S R56 Timing Chain Tensioner Mini Cooper S BUSTED Second Generation Faults & Fixes 23 Sep 4th, 2015 04:24 PM
MCS Timing Chain Tensioner A18XVM First Generation Faults & Fixes 12 Jul 8th, 2015 06:39 PM
2007 Cooper S "Timing Chain Tensioner Defect" igooba General Discussion 1 Feb 14th, 2014 09:40 AM
Timing chain tensioner bolt seal ORCHARD51 Second Generation MINI Cooper S 0 Aug 14th, 2013 03:28 PM
